maybe it is just that I have to work on the weekend but I cannot seem to get this to work
I am creating a timer of sorts with four sensors on it and I want to keep the fastest time I have ever got.
If I dimension my varibles as longs (which they need to be ) it does not work if they are dimesioned and int it works fine although I cannot have any time past 2.55 seconds.
here is the code sippet
if (besttime < oldtime) {
oldtime = besttime;
//store in eeprom
can anybody help me??
I am using pcwh v 3.22 and an 18f452
Mark
Posted: Sat Apr 23, 2005 4:45 pm
Not with what you posted. The problem must be elsewhere. Look at the LST file. Do some debugging and find out what the problem is.
If you are using the same functions to store your ints as well as longs in the eeprom that could be your problem? You may need to break your long into two ints and then same individually.
