I'm trying to setup timer 3 for use with the ccp on a PIC18F4331. The PCW help file claims that setup_timer_3() is the correct call to make to do this, and I have had no problems setting up timer 2 before. However, when I try to compile any code that includes a call to setup_timer_3() the compiler claims that "setup_timer_3" is an undefined identifier. This timer does exist on the processor I am using and I was hoping that someone had encountered this problem before. Is it a compiler bug, and if so is there a workaround? I just downloaded the most recent version of the compiler and still have the problem.
Thanks for the help.
--Arthur
Posted: Fri Apr 22, 2005 3:24 pm
