i2c2k Guest
16F88: Inable to read pin |
Posted: Wed Apr 20, 2005 2:28 pm |
hi!
I've got a problem with my PIC16F88 application: independent of what is going on, I always get a 1 when I read the PIN_A4 with input(PIN_A4).
I used following code:
#include <16F88.h>
#include "stdlib.h"
#fuses NOLVP, NOPUT, NOMCLR, BROWNOUT, NOWRT, NODEBUG, NOWDT, INTRC_IO, NOCPD
#byte OSCCON = 0x8F
OSCCON = 0b01101010;
port_b_pullups(TRUE);
setup_adc_ports(ADC_OFF|VSS_VDD);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
set_tris_a(0b00011000);
set_tris_b(0b00110000);
output_float(PIN_A4);
output_float(PIN_A3);
port_b_pullups(true);
while (1)
output_bit(PIN_B1, 1);
output_bit(PIN_A0, input(PIN_A4));
delay_ms(50);
output_bit(PIN_B1, 0);
delay_ms(50);
The flashing LED on PIN_B1 indicates, that the program is running. The LED on PIN_A0 should change its state depending on the state on PIN_A4, but the LED always glows!
Does anybody know what to do in this case?
Thank you![/code] |
i2c2k Guest
Posted: Wed Apr 20, 2005 2:29 pm |
By the way I use the compiler version 3.150 |
Posted: Wed Apr 20, 2005 3:06 pm |
In vs. 3.150, the setup_comparator() and setup_vref() functions don't
work properly for the 16F88. The comparators are being turned on
by the CCS code, when they should be turned off. This is what's causing
your problem.
To fix this problem, you need to comment out the calls to those functions,
and put in code to set the comparator and vref registers directly.
You need to make the following changes to your program, as shown in
bold below:
#byte CMCON = 0x9C
#byte CVRCON = 0x9D
setup_adc(ADC_OFF);
setup_spi(FALSE);
// setup_comparator(NC_NC_NC_NC);
CMCON = 7;
// setup_vref(FALSE);
CVRCON = 0; |
i2c2k Guest
Posted: Wed Apr 20, 2005 10:52 pm |
thanks very much!
do you know in which version this problem is fixed? |
Posted: Wed Apr 20, 2005 11:31 pm |
Those two problems were certainly fixed by vs. 3.222. I just did a
test compilation with that version and the .LST file code looks OK.
It was probably fixed a lot earlier than that, but I don't want to go through
and test a lot of different versions in order to find the exact one.
If you have a question about a certain version, post that version
and I'll check it. |
