Barney
Complier error with #include |
Posted: Wed Apr 20, 2005 12:19 am |
I am trying to use #include to make routines reusable and am having a complier error. My experience with compliers is that the pre-processor resolves all of the #xxx commands before handing the text to the complier. The CCS output seems to imply the included c files are complied seperately. This seems weird, the failing line is the struct declaration and the #device is in the initial included h file. Any info? The manual is rather cryptic and a simple test case I wrote does not have the problem. Compiler is Ver 3.212.
The main code is:
Code: | #include <16F88.h>
#device *=16
#fuses NOWDT, NOPROTECT, NOLVP, HS
#use delay(clock=20000000)
#use rs232(baud=9600, XMIT=PIN_B5, RCV=PIN_B2, PARITY=N, BITS=8, STREAM=COMM_1)
#define MAX 5
Int16 Registry_Map[MAX];
Int8 REG_Map[MAX * 2];
#locate REG_Map = Registry_Map
#include "modbus.c"
void main(){
int i;
for(i=0; i<MAX*2; i++)
REG_Map[i] = 0;
while(1) {
delay_ms(10);
COMM1_Service();
The included modbus.c file is long so I am showing the first 25 lines or so. The problem is with the struct declaration:
// MODBUS exception codes
#define Illegal_Function 1
#define Illegal_Data_Address 2
#define Illegal_Data_Value 3
#define Slave_Device_Failure 4
#define Acknowledge 5
#define slave_device_Busy 6
#define Negative_Acknoledge 7
#define Memory_Parity_Error 8
struct Comm_Port // <==== LINE 16 PROBLEM LINE
{ Int1 Respond; //respond to command
Int1 Initialized; //initialized
Int1 Packet; //packet ready for processing
Int8 Network_Address; //address of slave
Int8 CRClo_Index;
Int8 CRChi_Index;
Int8 Index; //ptr into buffer
Int8 Start; //starting register number
Int8 Finish; //last register number
Int8 Quantity; //number of registers
Int8 Buffer[MAX*2 + 5]; //data buffer, + 5 bytes for packet overhead
//slave addr, cmd, # data bytes, CRC Lo, CRC Hi
struct Comm_Port COMM1;
The complier output is:
Code: | Executing: "C:\Program files\Picc\CCSC.exe" "WaterMonitor.c" +FM +DF +LN +T -A +M +Z +Y=9 +EA
Memory usage: ROM=14% RAM=15% - 16%
0 Errors, 4 Warnings.
Executing: "C:\Program files\Picc\CCSC.exe" "modbus.c" +FM +DF +LN +T -A +M +Z +Y=9 +EA
*** Error 128 "C:\Documents and Settings\Barney\PIC-C\Water\modbus.c" Line 16(1,5): A #DEVICE required before this line
Halting build on first failure as requested.
BUILD FAILED: Tue Apr 19 22:59:39 2005
Posted: Wed Apr 20, 2005 12:58 am |
In the Project window in MPLAB, you probably have both your main C
source file and the modbus.c file. Remove modbus.c from the list.
Then it should compile without the #device error.
If you want to see modbus.c listed in the Project Window, then
add it to the "Other Files" section.
I tested this with MPLAB vs. 7.10. |
Mark
Posted: Wed Apr 20, 2005 6:10 am |
Quote: | you probably have both your main C
source file and the modbus.c file |
you definitely have both your main C
source file and the modbus.c file ![Smile](images/smiles/icon_smile.gif) |
Posted: Wed Apr 20, 2005 6:33 am |
test |
Barney
Posted: Wed Apr 20, 2005 1:12 pm |
You nailed it. I had modbus.c listed as a C file. I removed and no more errors. Thanks.
Barney |
