Unions |
Posted: Fri May 06, 2005 7:24 am |
It may seem trivial but I have searched the forum about unions and still have not solved my problem. With compiler version 3.224 I cannot compile any unions or maybe I am just coding them wrong. Here is test sample that I am missing somthing on. Any help would be appreciated.
#include <16f877a.h>
#DEVICE ADC=8
#fuses HS,NOLVP,NOWDT,PUT
#use delay (clock=20000000)
typedef union {
int i[4];
char letter[4];
long test;
} maybe;
maybe.i[2] = 4;
maybe.letter = "a";
maybe.test = 5500;
main () {
Thanks, |
Re: Unions |
Posted: Fri May 06, 2005 8:29 am |
Anonymous wrote: | It may seem trivial but I have searched the forum about unions and still have not solved my problem. With compiler version 3.224 I cannot compile any unions or maybe I am just coding them wrong. Here is test sample that I am missing somthing on. Any help would be appreciated.
#DEVICE ADC=8
typedef union {
int i[4];
char letter[4];
long test;
} maybe;
maybe.i[2] = 4;
maybe.letter = "a";
maybe.test = 5500;
main () {
Thanks, |
try
union tagname
} maybe;
Scott |
Posted: Fri May 06, 2005 8:38 am |
Well I tried it and no success. Did you actually compile that Code? The actual code I am trying to use is:
#DEVICE ADC=8
typedef union {
int i[4];
char letter[4];
long test;
} maybe;
maybe question;
question.i[2] = 4;
question.letter[1] = "a";
question.test = 5500;
main () {
Sam |
Mark
Posted: Fri May 06, 2005 9:02 am |
First, for a char use 'a' instead of "a".
Second, you have to make you assignments in a function not in the declaration!
#DEVICE ADC=8
typedef union {
int i[4];
char letter[4];
long test;
} maybe;
maybe question;
main () {
question.i[2] = 4;
question.letter[1] = 'a';
