Anybody understand #ID CHECKSUM?
stevev
PostPosted: Sun Feb 23, 2003 3:38 pm     Reply with quote
Does anyone know how to calculate a value at run time for a 16F877 which computes a ROM checksum which matches the value set by #ID CHECKSUM?
There are some old posts to c-code at Microchip but those links are broken. Here is what I'm trying to do, but the 'id' and 'calculated checksums don't match.
Thanks -steve-
verifyRom()
int16 romChecksum, flashChecksum;
int16 flash;
// -- get checksum from ID bits (set by compiler/linker at build time)
romChecksum = getenv("ID");
flashChecksum = 0;
// -- compute checksum of FLASH program ROM to verify program good
for (flash=0; flash flashChecksum += read_program_eeprom(flash);
flashChecksum &= 0x7ff;
// -- show error message and halt if checksum's don't match!!
if (flashChecksum != romChecksum)
printf("BAD CHECKSUM");
___________________________
Original Post ID: 12040
Tomi
Re: Anybody understand #ID CHECKSUM?
PostPosted: Mon Feb 24, 2003 9:32 am     Reply with quote
<font face="Courier New" size=-1>I think your problem is that you can not read ID locations at runtime (they are out of the normal memory address space).
:=Does anyone know how to calculate a value at run time for a 16F877 which computes a ROM checksum which matches the value set by #ID CHECKSUM?
:=There are some old posts to c-code at Microchip but those links are broken. Here is what I'm trying to do, but the 'id' and 'calculated checksums don't match.
:=Thanks -steve-
:=verifyRom()
:= int16 romChecksum, flashChecksum;
:= int16 flash;
:= // -- get checksum from ID bits (set by compiler/linker at build time)
:= romChecksum = getenv("ID");
:= flashChecksum = 0;
:= // -- compute checksum of FLASH program ROM to verify program good
:= for (flash=0; flash<getenv("PROGRAM_MEMORY"); ++flash)
:= flashChecksum += read_program_eeprom(flash);
:= flashChecksum &= 0x7ff;
:= // -- show error message and halt if checksum's don't match!!
:= if (flashChecksum != romChecksum)
:= printf("BAD CHECKSUM");
:=} ___________________________
Original Post ID: 12056
stevev
PostPosted: Tue Feb 25, 2003 1:39 pm     Reply with quote
I know that the config word for my fuses is 0x3F7E (at the bottom of the asm listing), so I tried subtracting (and adding too!) that from my checksums. I also have masked to 14-bits the sum, taken 1s complement and masked again to 14-bits ( as suggested by the MicroChip tech note) but this STILL doesn't give any values that match #ID CHECKSUM.
Does anybody verify their flash ROM contents match what was compiled? Doing this is a requirement for our product certification.
I'd appreciate any ideas or alternative methods that people are using to verify their ROMs.
Thanks again, -steve-
:=<font face="Courier New" size=-1>I think your problem is that you can not read ID locations at runtime (they are out of the normal memory address space).
:=:=Does anyone know how to calculate a value at run time for a 16F877 which computes a ROM checksum which matches the value set by #ID CHECKSUM?
:=:=There are some old posts to c-code at Microchip but those links are broken. Here is what I'm trying to do, but the 'id' and 'calculated checksums don't match.
:=:=Thanks -steve-
Original Post ID: 12091
PostPosted: Tue Feb 25, 2003 1:53 pm     Reply with quote
:=I know that the config word for my fuses is 0x3F7E (at the bottom of the asm listing), so I tried subtracting (and adding too!) that from my checksums. I also have masked to 14-bits the sum, taken 1s complement and masked again to 14-bits ( as suggested by the MicroChip tech note) but this STILL doesn't give any values that match #ID CHECKSUM.
:=Does anybody verify their flash ROM contents match what was compiled? Doing this is a requirement for our product certification.
:=I'd appreciate any ideas or alternative methods that people are using to verify their ROMs.
Here is a MicroChip appnote on checksums. It requires running
an external DOS program to modify the HEX file. The program
is also available on the following page.
<a href="http://www.microchip.com/1000/suppdoc/appnote/all/tb026/index.htm" TARGET="_blank">http://www.microchip.com/1000/suppdoc/appnote/all/tb026/index.htm</a>
Original Post ID: 12093
