fasteddye
High ADC values on 16F819 |
Posted: Wed Apr 13, 2005 9:38 pm |
Hi Everybody,
I am a newbie to CCS and microchip so bare with me if i say/do anything stupid. I am working on some code for a school project and the value that the adc is reading are not what i see on a voltmeter attached to the same pin. I am using 4 of the ADCs with the 5th pin as Vref+. The Vref is set to 2.5V from a voltage divider and the inputs to each of the pins is an opamp output which is a voltage between 0 to 2.5 (mainly .4 to 2.3V). The trouble is that i have a meter attached to a adc pin and its reading .4V and the chip is turning on flickering ledbank1 ( (0) means 0 leds on, (1) means 1 led on, etc) that should not come on unless there is a voltage greater than .74V (thus the threshold of 300 in the code below). I dont know whether i am not putting something in the code or if my math operations are wrong. My compiler version is 3.212. Please let me know if i have forgotten anything. Thanks for the help!!
Threshold Math:
2.5/1024 = .00244V = 2.44mV
300 * 2.44mV = .7324V
btw: this code is checking to see how close the voltages from the ADCs are and turn on 3 leds when the voltages are close enough....figured it might help
Code: | #include <16F819.h>
#device *=16 adc=10
#fuses INTRC_IO,NOWDT,NOPROTECT,NOLVP, NODEBUG
#use delay(clock=8000000)
int intensitySwitch = 0;
int startup = 0;
long adc0, adc1, adc2, adc3;
long adcdata0, adcdata1, adcdata2, adcdata3;
long baseline0, baseline1, baseline2, baseline3;
long threshold;
long highvalue;
int variance = 100;
float temp;
float minthreeledvalue;
// setup the adc converters
SETUP_ADC_PORTS(AN0_AN1_AN2_AN4_VSS_VREF);
SETUP_ADC(ADC_CLOCK_INTERNAL);
do {
// check adc0
SET_ADC_CHANNEL(0);
delay_us(10);
//delay_ms(1);
adc0 = READ_ADC();
// check adc1
SET_ADC_CHANNEL(1);
delay_us(10);
//delay_ms(1);
adc1 = READ_ADC();
// check adc2
SET_ADC_CHANNEL(2);
delay_us(10);
//delay_ms(1);
adc2 = READ_ADC();
// check adc3
SET_ADC_CHANNEL(4);
delay_us(10);
//delay_ms(1);
adc3 = READ_ADC();
threshold = 300;
adcdata0 = adc0;// - baseline0;
adcdata1 = adc1;// - baseline1;
adcdata2 = adc2;// - baseline2;
adcdata3 = adc3;// - baseline3;
// compares adc outputs
highvalue = adcdata0;
if(adcdata1 > highvalue) {
highvalue = adcdata1;
if(adcdata2 > highvalue) {
highvalue = adcdata2;
if(adcdata3 > highvalue) {
highvalue = adcdata3;
minthreeledvalue = 0.95 * (float)highvalue;
if(adcdata0 < threshold && adcdata1 < threshold && adcdata2 < threshold && adcdata3 < threshold) {
ledbank0(0);
ledbank1(0);
ledbank2(0);
ledbank3(0);
else if(adcdata0 >= minthreeledvalue && adcdata1 >= minthreeledvalue && adcdata2 >= minthreeledvalue && adcdata3 >= minthreeledvalue) {
ledbank0(3);
ledbank1(3);
ledbank2(3);
ledbank3(3);
else {
if(adcdata0 >= minthreeledvalue) {
ledbank0(2);
else if(adcdata0 < threshold) {
ledbank0(0);
else {
ledbank0(1);
if(adcdata1 >= minthreeledvalue) {
ledbank1(2);
else if(adcdata1 < threshold) {
ledbank1(0);
else {
ledbank1(1);
if(adcdata2 >= minthreeledvalue) {
ledbank2(2);
else if(adcdata2 < threshold) {
ledbank2(0);
else {
ledbank2(1);
if(adcdata3 >= minthreeledvalue) {
ledbank3(2);
else if(adcdata3 < threshold) {
ledbank3(0);
else {
ledbank3(1);
} while (TRUE);
Posted: Wed Apr 13, 2005 10:19 pm |
My suggestion is that if you have doubts about the output of the
read_adc(), then you should put in printf("%lx \n\r", value)" statements
and look at what you're getting.
Currently, you have a complicated group of if-else statements,
and the situation could be clarified instantly if you were to see
the actual output from the read A/D functions. |
fasteddye
Posted: Thu Apr 14, 2005 7:16 am |
where would the printf() statement output the value. I am programing the chip on a demo board using the icd 2 then moving it to my PCB. |
Posted: Thu Apr 14, 2005 12:50 pm |
I assume you don't have a LCD or a serial port circuit on your board.
In that case, you can temporarily add a transmit-only serial port to
your board. The 16F819 doesn't have a hardware UART module, so
you can use any free i/o pin for a software UART transmit pin.
Let's say that Pin B1 is a free pin on your PIC. Connect a wire between
pin B1 and pin 2 of the DB-9 connector for COM1, on the back of your PC.
Also connect another wire between Ground on your board and pin 5
of the COM1 DB-9 connector on your PC. (Make sure that you don't
accidently connect the PIC to pin 3 on the DB-9. That pin is the RS232
output from the PC and it's at a negative voltage, such as -10v. It might
damage the PIC's i/o pin if you connect it to the PIC).
You don't need a MAX232 type chip for this temporary UART.
Because of this, we will select the INVERT option for the software UART.
Here is a sample program that shows you how to do it. My demo board
has a 16F877 on it, so that's why this program uses that PIC. This
program reads the A/D value every 1/2 second and sends it to the PC.
I can turn the trimpot with a screwdriver and watch the output change
on my terminal window on the PC. Example of output:
0186
0186
0187
018e
0196
01a8
01b0
01ba
01c8
The range of values goes from 0 to 03FF. There are gaps in the
values displayed above because I only have a 3/4 turn trimpot and
I didn't try to make a fine adjustment with the screwdriver.
#include <16F877.H>
#device adc=10
#use rs232(baud=9600, xmit=PIN_B1, INVERT)
int16 result;
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
result = read_adc();
printf("%lx\n\r", result);
