3v190 compiler bug confirmation please ...
mpfj
PostPosted: Wed Apr 13, 2005 3:18 am     Reply with quote
Could someone please confirm that this is a known bug in 3v190, and has been fixed in later versions ?
Compiling the following code (for a PIC18F8720 under 3v190) ...
   signed int16 sum;
   sum = -100;
   if (sum >= 0) {
      sum = 100;
... produces the following ASM code ...
.................... void main() {
....................    signed int16 sum;
0004:  CLRF   FF8
0006:  BCF    FD0.7
0008:  CLRF   FEA
000A:  CLRF   FE9
000C:  MOVLW  0F
000E:  MOVWF  FC1
0010:  MOVLW  07
0012:  MOVWF  FB4
....................    sum = -100;
0014:  MOVLW  FF
0016:  MOVWF  07
0018:  MOVLW  9C
001A:  MOVWF  06
....................    if (sum >= 0) {
001C:  BTFSS  07.7                               <---- WRONG !!
001E:  GOTO   0022                               <---- WRONG !!
....................       sum = 100;
0022:  CLRF   07
0024:  MOVLW  64
0026:  MOVWF  06
0028:  SLEEP
As you can see the code for "if (sum >= 0) {" is plainly wrong. Could someone compile using a later version of the compiler to see what they get ?
Am I right in assuming that a signed integer would have the top bit set if it's negative, and the top bit clear if it's positive ? If so, I'll have to code a work-around for my current project.
PostPosted: Wed Apr 13, 2005 4:04 am     Reply with quote
CS PCH C Compiler, Version 3.223,               13-avr.-05 12:01
               Filename: C:\Mes documents\electronique\test\test.LST
               ROM used: 50 bytes (0%)
                         Largest free fragment is 65536
               RAM used: 7 (0%) at main() level
                         7 (0%) worst case
               Stack:    0 locations
0000:  GOTO   0004
....................  #device PIC18F8720
0004:  CLRF   FF8
0006:  BCF    FD0.7
0008:  CLRF   FEA
000A:  CLRF   FE9
000C:  MOVF   FC1,W
000E:  ANDLW  C0
0010:  IORLW  0F
0012:  MOVWF  FC1
0014:  MOVLW  07
0016:  MOVWF  FB4
0018:  MOVF   FB4,W
001A:  BCF    FA1.6
001C:  MOVLW  FF
001E:  MOVWF  07
0020:  MOVLW  9C
0022:  MOVWF  06
0024:  BTFSC  07.7
0026:  BRA    0030
0028:  BRA    002A
002A:  CLRF   07
002C:  MOVLW  64
002E:  MOVWF  06
0030:  SLEEP
regards
PhilippeM
[/code]
mpfj
PostPosted: Wed Apr 13, 2005 4:53 am     Reply with quote
Thanks for the confirmation.
I've just used the bit_test() function to get round it.
// if sum is negative ...
if (!bit_test(sum, 15)) {
