The fastest way to set and clear multible ports ?
Goto page 1, 2  Next
James Bolver
PostPosted: Tue Apr 12, 2005 5:04 am     Reply with quote
Hi, I have 7 outputs on two different ports. At any given time I need 6 to be floating and 1 to be high. Is there a better way to do that other then setting each one depending on an if statement ?
Another problem is that it needs to happen fast so I would rather not just set all pins to float then figure out which needs to be high. I was thinking of using this but CCS does not compile because i is not a constant.
for (i=PIN_C0; i<PIN_C6; i++) {
 if (i != toggle_variable)
  output_float(i);
  output_high(i);
Obviously this is not for two ports, but no problem since it does not work anyway. Also, I have inputs on the remaining pins.
Thanks for your time!
James Bolver
Mark
PostPosted: Tue Apr 12, 2005 6:22 am     Reply with quote
ORing the tris register with a value will make the pin an input (float)
say we have trisc defined somewhere and we want C0,C1,C2, and C4 to be inputs (float)
trisc |= 0b00010111; // make them inputs
want them to be outputs then
trisc &= 0b11101000; // make them outputs
You can do the same for setting outputs high or low
portc |= 0b00010111; // make them high
portc &= 0b11101000; // make them low
If usings a pic18 it is better to use the lat register. See the datasheet and read about read write modify.
James Bolver
PostPosted: Tue Apr 12, 2005 9:03 am     Reply with quote
Is trisc a key word in your version of CCS ?
Am I missing somthing here Confused
Mark
PostPosted: Tue Apr 12, 2005 9:08 am     Reply with quote
It is a register name. You will have to define it base on your PIC. Something like
#byte portc = 0x07
#byte trisc = 0x87
James Bolver
PostPosted: Tue Apr 12, 2005 9:18 am     Reply with quote
#byte portb = 6
#byte portb_tris = 0x00
nevermind. Very Happy [/code]
Mark
PostPosted: Tue Apr 12, 2005 9:19 am     Reply with quote
that doesn't look right for the portb_tris.
James Bolver
PostPosted: Tue Apr 12, 2005 10:31 am     Reply with quote
I dont know. Its from the CCS help file. I havn't had a chance to try it yet,
I do have a problem that I dont want to effect the rest of the pins on either port. Just the ones I'm interested in.
I'll need to come up with somthing for that. Maybe storing in the bits I dont change, setting the ones I do and restoring the old ones.
Mark
PostPosted: Tue Apr 12, 2005 10:54 am     Reply with quote
Yeah, that's what the code I posted does.
James Bolver
PostPosted: Tue Apr 12, 2005 1:39 pm     Reply with quote
Confused Really ?
The &= must be throwing me off then. Isn't that going to set my first two bits (lets imagine I'm using the last 6) regardless of if I want it to or no ?
So if I have
trisc = 10111011 in my program (C2 is my currently high, C6 and C7 is doing other stuff)
Then I want to change C2 from high to float and light up C3 you are saying use & but that will screw up the mystery bits 7 and 6 (which I dont care to check the state of before I do this), so ^
trisc |= 00000100; //make C2 float
trisc ^= 00001000; //XOR will do this I think
now trisc should be 10110111 no ?
THEN I would have to go ahead and make that output correct too.
Hmmm... If I have the first nibble set to LOW and then I switch that port to input is it still LOW when I switch back ?
Mark
PostPosted: Tue Apr 12, 2005 1:55 pm     Reply with quote
James Bolver wrote:
Confused Really ?
So if I have
My example didn't use the last 6. It used the ones that I stated. But for your example:
trisc |= 0b00000100; //make C2 float
trisc &= 0b11110111; //make C3 output
portc |= 0b00001000; //set c3 high
PostPosted: Tue Apr 12, 2005 1:59 pm     Reply with quote
When Mark said it "doesn't look right" he wasn't expressing doubt,
he was just using a conversational tone. He means it's dead wrong.
Just to let you know.... Mr. Green
I searched the CCS help file that comes with PCM vs. 3.22 for portb_tris
and there's only one article that has that string in it. It has these lines:
#byte portb = 6
#byte portb_tris = 0x86
James Bolver
PostPosted: Tue Apr 12, 2005 2:14 pm     Reply with quote
Oh, what is it that 0x86 does ?
newguy
PostPosted: Tue Apr 12, 2005 2:19 pm     Reply with quote
It's an address. The address of the port b tris register in the pic's RAM. Or it should be, I didn't check it. Take a look at the pic's data sheet - there will be a section on its' memory organization. Look for a table of the "special function registers" - port b will be at address 6, and I'm assuming that port b's tris register will be at 0x86.
PostPosted: Tue Apr 12, 2005 2:20 pm     Reply with quote
It is the _address_ of the register.
The '#byte' operator, allows you to associate a particular 'name' to I/O on a particular address. The data sheet for the chip, will tell you what address each register is on (it changes for the larger '18' chips, and the smaller '12' chips). '0x86', is the address of the portb TRIS register, on the 16 chips. Setting this to '0', mans that when you talk to the variable 'portb_tris', you will actually talk to the indirect addressing register, and could destroy data anywhere in memory...
To send '0' to portb_tris, involves first stting the register address with the #byte operator, then having something like:
portb_tris=0;
Which transfers '0' to the register now referred to by 'portb_tris'.
James Bolver
PostPosted: Tue Apr 12, 2005 3:21 pm     Reply with quote
Does the output state reset every time or does it stay in memory ?
IE: If I set the trisc to half low and half high then make portc inputs then switch back to outputs are all low again?
Goto page 1, 2  Next
Page 1 of 2
