16F88 Comparator Problem |
Posted: Wed May 18, 2005 8:31 pm |
Has anyone experienced a problem reading C1OUT from CMCON on a 16F88? I can see C1OUT on RA3 but I cannot read it in code.
#include <16F88.h>
#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,NOMCLR
#Use FAST_IO(A)
#Use FAST_IO(B)
#BYTE VRCONREG = 0x9D
#BYTE CMCON = 0x9C
main() {
int8 Comp;
SET_TRIS_A(0x03);
SET_TRIS_B(0x04);
OUTPUT_HIGH(PIN_B1);
DELAY_MS(1000);
OUTPUT_LOW(PIN_B1);
VRCONREG=0xE2;
CMCON = 6;
{ Comp=CMCON;
if(BIT_TEST(Comp,6)){
Delay_us(100);
OUTPUT_HIGH(PIN_B3);}
if(!BIT_TEST(Comp,6)){
Delay_us(100);
OUTPUT_LOW(PIN_B3);}
Posted: Thu May 19, 2005 12:10 am |
It looks like you're trying to use the internal Vref with the comparators
in mode 6. However, according to the data sheet, the internal Vref is
only used in mode 2. I can confirm this. I ran the following test
program and it only worked in mode 2.
I used a 16F88 on a PicDem2-Plus board, and I set the trimpot for
an output voltage of 2.5v. When I ran the program below, and
moved the trimpot wheel back and forth very slightly, I got this output:
Quote: |
00
00
00
01
01
01
00
00
00
01
01
01
etc.
Code: | #include <16F88.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock=8000000)
#use RS232(baud=9600, xmit=PIN_B5, rcv=PIN_B2, ERRORS)
setup_oscillator(OSC_8MHZ);
setup_comparator(A0_VR_A1_VR); // Comparator mode 2
setup_vref(VREF_LOW | 12); // Set internal Vref = Vdd/2
printf("%x\n\r", C1OUT); // Display C1 output every 1/2 second
