static? SLEEP MODE
Christophe
static? SLEEP MODE
PostPosted: Thu May 19, 2005 5:16 am     Reply with quote
#INT_EXT
void ext_isr() {
static short button_pressed=FALSE;
   if(!button_pressed)        // if button action and was not pressed
      button_pressed=TRUE;    // the button is now down
      sleep_mode=TRUE;        // activate sleep
      printf("The processor is now sleeping.\r\n");
      ext_int_edge(L_TO_H);   // change so interrupts on release
   else                       // if button action and was pressed
      button_pressed=FALSE;   // the button is now up
      sleep_mode=FALSE;       // reset sleep flag
      ext_int_edge(H_TO_L);   // change so interrupts on press
   if(!input(PIN_B0))         // keep button action sychronized wth button flag
   delay_ms(100);             // debounce button
Hello again,
this question is about the variable button_pressed. It gets initialised in the isr() as FALSE. How can it ever get TRUE when isr() is called? Shouldn't it be declared outsite the function?
In main:
      if(sleep_mode)          // if sleep flag set
         sleep();             // make processor sleep
      printf("The count value is:  %5ld     \r\n",counter);
      counter++;              // display count value and increment
      delay_ms(1000);         // every second
What is the processor doing after sleep(); ? Is he still able to poll i/o, to do instructions in general?
-what is sleep mode-
Mark
PostPosted: Thu May 19, 2005 6:20 am     Reply with quote
How can it get set to TRUE? Did you look at the code that you posted?
maybe this will make it clearer
   if(button_pressed==FALSE)        // if button action and was not pressed
Christophe
PostPosted: Thu May 19, 2005 6:43 am     Reply with quote
Mark,
I mean when ENTERING the isr(); the variable is set FALSE!
So it will never get to the else statement.. no?
Mark
PostPosted: Thu May 19, 2005 6:44 am     Reply with quote
Not when it is declared as "static"
