Keyscan code
Sugiman
Keyscan code
PostPosted: Wed Apr 06, 2005 3:20 am     Reply with quote
I'm trying to shorten some of the routines in this program, specifically the keyscan ones as posted below. Is there any way to put it in a "for" loop and have it set the SCAN ports low and high once per cycle instead of having to list them all out? I tried to do it with a const array but the compiler gave me an error msg along the lines of "Expression must evaluate to a constant"
Here's the part of the header where SCAN_xx is initialized
#define  SCAN_01   PIN_A0   // k01,k02,k03,k04
#define  SCAN_02   PIN_A1   // k05,k06,k07,k08
#define  SCAN_03   PIN_A2   // k09,k10,k11,k12
#define  SCAN_04   PIN_A3   // k13,k14,k15,k16
#define  SCAN_05   PIN_A5   // k17,k18,k19,k20
#define  SCAN_06   PIN_B0   // k21,k22,k23,k24
#define  SCAN_07   PIN_B1   // k25,k26,k27,k28
#define  SCAN_08   PIN_B2   // k29,k30,k31,k32
#define  SCAN_09   PIN_B3   // k33,k34,k35,k36
#define  SCAN_10   PIN_C0   // k37,k38,k39,k40
#define  SCAN_11   PIN_C1   // k41,k42,k43,k44
#define  SCAN_12   PIN_C3   // k45,k46,k47,k48
#define  SCAN_13   PIN_C4   // k49,k50,k51,k52
#define  SCAN_14   PIN_C5   // k53,k54,k55,k56
#define  SCAN_15   PIN_C6   // k57,k58,k59,k60
#define  SCAN_16   PIN_C7   // k61,k62,k63,k64
And here's the key_scan function I'm hoping to shorten
void key_scan(void)
   int n;
   n = 0;
   output_low(SCAN_01);   delay_us(500);
   gScanBuf[n++] = ~gScanIn;
   output_high(SCAN_01);
   output_low(SCAN_02);   delay_us(500);
   output_high(SCAN_02);
   output_low(SCAN_03);   delay_us(500);
   output_high(SCAN_03);
   output_low(SCAN_04);   delay_us(500);
   output_high(SCAN_04);
   output_low(SCAN_05);   delay_us(500);
   output_high(SCAN_05);
   output_low(SCAN_06);   delay_us(500);
   output_high(SCAN_06);
   output_low(SCAN_07);   delay_us(500);
   output_high(SCAN_07);
   output_low(SCAN_08);   delay_us(500);
   output_high(SCAN_08);
   output_low(SCAN_09);   delay_us(500);
   output_high(SCAN_09);
   output_low(SCAN_10);   delay_us(500);
   output_high(SCAN_10);
   output_low(SCAN_11);   delay_us(500);
   output_high(SCAN_11);
   output_low(SCAN_12);   delay_us(500);
   output_high(SCAN_12);
   output_low(SCAN_13);   delay_us(500);
   output_high(SCAN_13);
   output_low(SCAN_14);   delay_us(500);
   output_high(SCAN_14);
   output_low(SCAN_15);   delay_us(500);
   output_high(SCAN_15);
   output_low(SCAN_16);   delay_us(500);
   output_high(SCAN_16);
Thanks for your help =)
DragonPIC
PostPosted: Wed Apr 06, 2005 10:27 am     Reply with quote
#byte port_a = 5
#byte port_b = 6
#byte port_c = 7
int i;
port_a = 0x01;
for(i=0;i<4;i++)
port_a<<=1;
port_a<<=1;
I think this should work. You sould get the point on how you could probably do the rest and crunch.
You could also probably combine some diff. ports code by using a pointer.
int8 *port;
port = port_a;
-Matt
Sugiman
PostPosted: Wed Apr 06, 2005 7:51 pm     Reply with quote
Thanks for the help, I'll give it a try =)
