write_program_eeprom/read_program_eeprom bug?there a bug
setb2609
PostPosted: Sat Apr 02, 2005 5:48 am     Reply with quote
hi,
is there a bug wirh write_program_eeprom or read_program_eeprom in the PCH 3.214 compiler.
I have a bootloader that uses write_program_eeprom and read_eeprom_program to write and reread for verify the data. everything works fine from the bottom address up to address $6000. but exactly at $6000 there occurs a write failure over and over again.
As I realy can't see any problem with the code I would like to ask if there are any known problems (and maybe workarounds) ???
setb2609
PostPosted: Sat Apr 02, 2005 5:53 am     Reply with quote
btw. the problem occurs with a PIC18F452 - but I haven't tested different devices ...
PostPosted: Sat Apr 02, 2005 11:38 am     Reply with quote
Everything works fine from the bottom address up to address $6000.
But exactly at $6000 there occurs a write failure over and over again.
You didn't show your #fuses statement. Do you have the WRT3 fuse
in your #fuses statement ? If so, it will write-protect that block.
I suggest that you remove it. From the data sheet:
WRT3: Write Protection bit (1)
1 = Block 3 (006000-007FFFh) not write protected
0 = Block 3 (006000-007FFFh) write protected
