Seemingly Simple Syntax Question
Jerry Finsen
PostPosted: Wed Feb 26, 2003 4:13 pm     Reply with quote
The following snippet fails to compile the call to Test2: "Bad expression syntax:.
What am I missing?
include <16F877.h>
// Prototypes
void Test1(Char String);
void Test2(int x, Char String);
// Main
Test1( "Hello World");
Test2(1, "Hello World");
// Subroutines
return;
void Test2(int x, char String)
return;
___________________________
Original Post ID: 12135
Hans Wedemeyer
Re: Seemingly Simple Syntax Question
PostPosted: Wed Feb 26, 2003 4:39 pm     Reply with quote
When you pass a string you are passing a char pointer.
I modified the code it should work now...
hansw
:=The following snippet fails to compile the call to Test2: "Bad expression syntax:.
:=What am I missing?
:=include <16F877.h>
:=// Prototypes
:=void Test1(char* String);
:=void Test2(int x, char* String);
:=// Main
:=void main() {
:=Test1( "Hello World");
:=Test2(1, "Hello World");
:=// Subroutines
:=return;
:=return;
Original Post ID: 12141
PostPosted: Wed Feb 26, 2003 5:11 pm     Reply with quote
CCS doesn't permit pointers to constant strings.
You have to copy the string to a ram buffer first.
Example:
<PRE>
#include "16F877.h"
#fuses HS, NOWDT,NOPROTECT,PUT,BROWNOUT, NOLVP
#use Delay(clock=8000000)
<BR>
char temp[20];
<BR>
strcpy(temp, "Hello World");
<BR>
Test1(temp);
<BR>
<BR>
<BR>
printf("\%s", String);
</PRE>
Original Post ID: 12142
Jerry Finsen
PostPosted: Wed Feb 26, 2003 5:12 pm     Reply with quote
I copied your code into the IDE and tried to compile ... same error. Mysterious that it doesn't complain about the call to Test1.
Using 3.146 of the compiler.
Original Post ID: 12143
