setting RTCC_DIV_2 and RTCC_DIV_4
PostPosted: Sun Mar 27, 2005 2:01 am     Reply with quote
Hi all
I am using Timer0 to set the sampling frequency. I have to work with 7 different frequency values. There are 7 different "if" statement and every statement uses its own sampling rate.
Forexample:1Khz,2Khz,3Khz,6Khz,8Khz,12Khz,16Khz so every time I need to set the setup_timer_0(RTCC_INTERNAL|RTCC_DIV_?); value. How can i do this with only one variable. Like a for
RTCC_DIV_2 and after that if i need RTCC_DIV_8, i shift a 2 bits.Is it possible??
Best Regards
Mark
PostPosted: Sun Mar 27, 2005 8:25 am     Reply with quote
Read the datasheet on setting up the timers. You can do it manually. Beaware that there are only a few divide bys allowed. Read the datasheet and this will become more clear.
