Need help with ADC of PIC8720
csshah
PostPosted: Tue Mar 22, 2005 8:37 am     Reply with quote
Hi all
I am using a simple code to read an audio input on channel 0 of pic8720. I dont know what I am doing wrong but when i put REF voltage as VDD and VSS it gives me some fixed values like 0000 0001 0002 on screen eventhough I didnt connect any ref voltage on Vref+ pin, but when i put setup_port_a(VSS_VREF) it gives me some hex values which seems to be correct. I want to display dB value of audio signal on LCD screen.
#include <18F8720.H>
#device *=16 ADC=10
#fuses HS,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#use delay(clock = 20000000)
#include<math.h>
#include <stdio.h>
#include <LCD_4bit_test.c>
//setup_adc_ports(NO_ANALOGS);
//SET_TRIS_b(0xFF);
#define CURSOR '~'
#define menu PIN_B4
#define up   PIN_B3
#define down PIN_B5
//#use RS232 (BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7)
void main (void){
   int16 val;
   float f;
   int db;
   lcd_init();      //LCD initialization
   delay_ms(800);
   set_tris_a(0xFF);
   //setup_port_a( ANALOG_AN0_TO_AN5 | VSS_VREF);
   setup_port_a( ANALOG_AN0_TO_AN5 | VSS_VDD);
   setup_adc( ADC_CLOCK_DIV_32 );
   while(1){
      set_adc_channel( 0 );
      delay_ms(10);
      val=read_adc();
      delay_ms(10);
      printf(lcd_putc,"%Lx",val);
      //lcd_putc(" ");
      //f=(float)val*5/1024;
      //printf(lcd_putc,"%2.3f",f);
      //lcd_putc(" ");
      //db=20*log10((f*0.707)/0.775);
      // printf(lcd_putc,"%2.3f",(float)val*4.74/1024);
      //printf(lcd_putc,"%ddB",db);
      //delay_ms(1000);
      //lcd_putc("\f");
PostPosted: Tue Mar 22, 2005 11:05 am     Reply with quote
Start by connecting a reference voltage...
The ADC, will not work without a reference source. With the end of the ADC reference left floating, the values are just going to depend on 'luck' on the chip...
csshah
PostPosted: Tue Mar 22, 2005 12:10 pm     Reply with quote
Hi
now I connected VREF+ and VREF- as +5 and -5 volts. but still in above program I am reading value of 8dB signal as 1023(val) now using this how can I display dB value on screen and is 1023 indicates number of samples per clock??
reply soon
thanks for help
rwyoung
PostPosted: Tue Mar 22, 2005 1:09 pm     Reply with quote
PIC ADCs can't tolerate reference voltage more than a diode drop below ground. Typically VREF- is either ground or some voltage between ground and VREF+.
PIC ADCs are unipolar input only. If you aren't level shifting your audio signal, then you will never get the right answer.
Rob Young
