In a project [sort of calculator], I need 9 digits and floating point calculation; I know that ccs c supports 32 bit floating points (IEEE) which provides 24 bits for mantissa. that makes a 8-digits number. but I need at least 30-bit mantissa for 9 digits.
Is there a way for me to calculate both 32 bit floating point and store 9 digit numbers as a whole? can anybody help?
Posted: Tue Mar 22, 2005 6:41 am
Not without writing your own maths library.
However remember that you could (for instance), use a 32bit integer, and another int8, as a scale factor. Depending what arithmetic you want, this could be relatively easy to code.
