LCD interface on Port J
csshah
PostPosted: Fri Mar 18, 2005 12:10 pm     Reply with quote
Hi all
I am interfacing LCD with PIC 18F8720 with CCS version 3.219 and I am using driver (4 bit interface) for 20x2 LCD given with the compiler. This driver uses pin A1,A2,A3 for control and lower nibble of port D for data. Now if I want to change the control pins to other port like J(J1,J2,J3) then what I need to change in order to do that. I changed the given code with address of port J and TRIS J but it didnt work. so can you tell me what else need to be changed.
////                             LCDD.C                                 ////
////                 Driver for common LCD modules                      ////
////  lcd_init()   Must be called before any other function.            ////
////  lcd_putc(c)  Will display c on the next position of the LCD.      ////
////                     The following have special meaning:            ////
////                      \f  Clear display                             ////
////                      \n  Go to start of second line                ////
////                      \b  Move back one position                    ////
////  lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1)     ////
////  lcd_getc(x,y)   Returns character at position x,y on LCD          ////
////        (C) Copyright 1996,1997 Custom Computer Services            ////
//// This source code may only be used by licensed users of the CCS C   ////
//// compiler.  This source code may only be distributed to other       ////
//// licensed users of the CCS C compiler.  No other use, reproduction  ////
//// or distribution is permitted without written permission.           ////
//// Derivative programs created using this software in object code     ////
//// form are not restricted in any way.                                ////
// This structure is overlayed onto the data ports so that you may use
// whatever ports you desire
struct lcd_pin_map
  BOOLEAN dummy;      // PinA0 is not used
  BOOLEAN enable;     // PinA1
  BOOLEAN rw;         // PinA2
  BOOLEAN rs;         // PinA3
  int unusedA  : 4;   // The rest of portA
  int unusedB;        // portB is not used
  int unusedC;        // portC is not used
  int     data : 4;   // lower nibble of portD is used for data lines
  int unusedD  : 4;   // The rest of portD
} lcd;
#if defined(__PCH__)
  #locate lcd = 0xF88 <--- here I made change in address for port J
#else
  #locate lcd = 5
struct lcd_tris_map
  int control  : 3;
} lcdtris;
  #locate lcdtris = 0xF9A <-- here I changed address of tris port J
#else
  #locate lcdtris = 0x85
#define set_tris_lcd(x) lcdtris.data = (x); lcdtris.control = 0;
#define lcd_type 2           // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40    // LCD RAM address for the second line
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
                             // These bytes need to be sent to the LCD
                             // to start it up.
                             // The following are used for setting
                             // the I/O port direction register.
#define LCD_WRITE    0       // For write mode all pins are out
#define LCD_READ     15      // For read mode data pins are in
BYTE lcd_read_byte() {
      BYTE low,high;
      set_tris_lcd(LCD_READ);
      lcd.rw = 1;
      delay_cycles(1);
      lcd.enable = 1;
      delay_cycles(1);
      high = lcd.data;
      lcd.enable = 0;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(1);
      low = lcd.data;
      lcd.enable = 0;
      set_tris_lcd(LCD_WRITE);
      return( (high<<4) | low);
void lcd_send_nibble( BYTE n ) {
      lcd.data = n;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(2);
       lcd.enable=0;
Mark
PostPosted: Fri Mar 18, 2005 12:46 pm     Reply with quote
is the data on port J as well?
csshah
PostPosted: Fri Mar 18, 2005 12:50 pm     Reply with quote
No there is no data on port J, I am using only lower nibble of D for data and port B for pushbuttons. all other ports are free. and I am using microchip 80 pin TQFP board
[url]
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=84&useSecondary=true&device=en010058&ds=on&uguide=on&dnotes=on&errt=on&mig=on&tut=on&refm=on&broc=on[/url]
Mark
PostPosted: Fri Mar 18, 2005 8:03 pm     Reply with quote
Well then that's your problem!
struct lcd_pin_map
  int unusedA;
  int unusedB;
  int unusedC;
  int unusedE;
  int unusedF;
  int unusedG;
  int unusedH;
  BOOLEAN dummy;
  BOOLEAN enable;
  BOOLEAN rw;
  BOOLEAN rs;
  int unusedJ : 4;
} lcd;
  #locate lcd = 0xF80
#else
  #locate lcd = 5
struct lcd_tris_map
  int unusedA;
  int unusedB;
  int unusedC;
  int unusedE;
  int unusedF;
  int unusedG;
  int unusedH;
  BOOLEAN dummy;
  int control  : 3;
  int unusedJ : 4;
} lcdtris;
  #locate lcdtris = 0xF92
#else
csshah
it works now!!!
PostPosted: Mon Mar 21, 2005 7:51 am     Reply with quote
Hey Mark!!!
Thanks a lot man!! You r GREAT!!!
I really appreciate ur help.
take care
