how to set CCS menu?
cindyw
PostPosted: Thu Mar 17, 2005 8:45 pm     Reply with quote
Anybody can explane the following two issues? Thanks.
1, Menu of Project/ set language toolsuite/, there are two options: CCS compiler and CCS compiler for PIC 12/14/16/18.
May I know which to select. what is the difference?
2, in the workspace, If I add two (*.c) file under Source File, there is a lot errors. However, if I add them under Other Files. No errors anymore. Why?
These two *.c file is included by main.c
Confused
CC
Mark
PostPosted: Sat Mar 19, 2005 7:55 pm     Reply with quote
CCS compiler for PIC 12/14/16/18 is the right one. The other one doesn't work.
CCS is a single source compiler and you can only have 1 source file. You can include other files from the main file. If you add mulitple C files to the project, the IDE will invoke the compiler for each of the files and give you the errors.
PostPosted: Sun Mar 20, 2005 5:37 am     Reply with quote
Thanks.
I finally get a explanation for what I observed.
