Req; variables, pointers size
amaye
PostPosted: Wed Mar 16, 2005 3:53 pm     Reply with quote
I would like to know some variables size for two mcus. I guess that it is tied to the architecture so it be different from pic16 to pic 18.
Could someone give :
For a PIC16F876A
char *Var = ???
char Var = ???
short Var = ???
int Var = ???
long Var = ???
For a PIC18F6720
char *Var = ???
char Var = ???
short Var = ???
int Var = ???
long Var = ???
I want these infos cause I have some weird compiler errors that doesn't allow me to do some stuff as ( on a pic16f876a ) :
char *Var = 0x100
the error telling me 0x110 isnt between [0..255].
This is kinda confusing, I cannot believe a pointer on a byte could be only 0 to 255, haha...
Mebbie it may be related to the #locate which is associated with
Thank you very much
Warm regards
Arnaud
PostPosted: Wed Mar 16, 2005 4:12 pm     Reply with quote
For a PIC16F876A
char *Var = 8 bits, but it can be 16 bits if you add: #use device *=16
char Var = unsigned 8 bits
short Var = 1 bit
int Var = unsigned 8 bits
long Var = unsigned 16 bits
Example of how to enable 16-bit pointers for the PCM compiler:
#include <16F876A.H>
#device *=16  // Put this statement on the next line after the #include.
main()
For a PIC18F6720
char *Var = 16 bits
short Var = 1 bit
It may be easier if you use CCS's alternate data types. Then you
can instantly see the size:
int1
int8
int16
int32
These are all unsigned.
amaye
PostPosted: Thu Mar 17, 2005 2:29 am     Reply with quote
Ok, this new directive is working properly as expected
Thank you
Arnaud
