Printf - Please help
kometen
PostPosted: Tue Mar 15, 2005 12:14 pm     Reply with quote
I have a signed long in the range of -5000 to +5000 representing a temperature between -500,0 to +500,0 degree C
When I try to convert the value to a string using the fprintf it works fine
for values between -500,0 to -1,0. But when my value is -9 (equals -0.9)
the minus sign disappears.
Anyone have the correct printf setup to solve this problem?
Thanks in advance
Poul Shocked
PostPosted: Tue Mar 15, 2005 2:25 pm     Reply with quote
Can you post a little demo program ? Then we'll just try it.
Also post your compiler version and the PIC you're using.
SherpaDoug
PostPosted: Tue Mar 15, 2005 3:39 pm     Reply with quote
Here is what I had to do recently:
           takereadings();   //reads temperature and pressure
            if (sT)     // positive temp   sT is a boolean giving the sign of temperature
               fprintf(fish,"%%temp=+");
            else        // negative temp
               fprintf(fish,"%%temp=-");
            fprintf(fish,"%02d.%01u pres=%04lu\n\r",T,(int)dT,P); // Send data to fish
        // %temp=sxx.x pres=xxxx<CRLF>
There ought to be a better way!
kometen
My code
PostPosted: Wed Mar 16, 2005 2:37 am     Reply with quote
Yes, there ought to be a better way.
I am using pcwh 3.216 .
My code:
int tanktoshow;
signed long temperature[20];
char string [20];
tanktoshow=1;
I am using this line to load the signed long 'temperature[tanktoshow]' to
sprintf(string,"%3.3Ld.%01Ld",temperature[tanktoshow]/10,temperature[tanktoshow]%100);
I want to have a readout with 1 decimal.
At values of 250, -250, 99,-99,9,-9 the minus sign works perfectly.
but at values -0.9, .. to -0.1 the minus sign is not added to the string.
Any nice solution is appreciated
best regards
Poul
