how can i tell this if this is working?
hoss`
PostPosted: Wed Mar 16, 2005 2:15 pm     Reply with quote
I'm kind of a noob when it comes to programming the pic and I was hoping for some help with a few simple questiosn...
here's what i'm trying to do. I'm using an LM34 temperature sensor and all I want to do is get the digital voltage to be able to eventually output serially. What I've done so far is follow the application note of the LM34 and output both the value of LM34 and a reference voltage of 2.55v to the PIC.
Here's the code I've got so far....
#include <16F874.H>
   double temp_in = 0;
   double temp = 0;
   int i;
   // Setting up Port A to do ADC on Pin 2
   setup_port_a(ALL_ANALOG);
   set_adc_channel(0);
   // Allowing a delay to make sure the ADC
   // works properly
      for (i = 0; i < 19; i++)
         temp_in = temp_in + read_adc();
         delay_ms(50);
      temp = temp_in / 20;
Info about what I'm using: PIC 16f874, compiler: CCS C compiler
I'm not quite sure how the ADC really works. From what I understand it'll compare the voltage with 2.55v (my reference voltage) / 255 (8bit adc) = 0.01 = 10mV. 10mV output from the LM34 = 1 degree. I read an application where someone used that and it seems to make sense to me.
What I want to do is be able to see what kind of value I will be outputting. Is there a way to do a printf and see what value I'm getting? Also am I using the ADC correctly or no?
As you can see I'm really unsure of what I'm doing so any help will be much appreciated. Thanks in advance! Very Happy
PostPosted: Wed Mar 16, 2005 3:39 pm     Reply with quote
You talk about your reference voltage. What pin is it connected to?. You need to tell the ADC to use the reference voltage. The key is a table in the chip data sheet, entitled 'register 11-2', 'ADCON1 register'. The instruction 'setup_port_A', actually sets this register. If you look at the tble, the top line showing all the pins used as analog, has Vref, coming from the chip supply voltage, not the external pins. The setting 'ANALOG_RA3_REF', instead selects Vref to be on RA3, and the rest of portA to be used as analog inputs. To use a 2.55v reference, you will need to use this setting (or one of the others with less analog pins enabled).
Yes, you can do a printf. You need to add a #use RS232 statement (there are dozens of examples in the examples directory of this), and connect the output pin, via a MAX232 or similar RS232 transceiver to the serial input pin of a PC (and the 0V connections between the two units as well). Then you can just add a printf to see what is in your temp register.
Since you are adding 20 readings, then looping, the statement to zero the temp_in register should be moved to the line in front of the 'for' statement, or the contents will keep growing, and quickly overflow the storage.
You should change your type definitions to 'int16'. Double is not a supported type, unless you have defined it for yourself.
hoss`
PostPosted: Mon Mar 21, 2005 10:38 am     Reply with quote
okay here's an updated version of my code...
#include <16F874.H>
#use rs232(DEBUGGER)
   int16 temp_in = 0;
   int16 temp = 0;
   int i;
   setup_port_a(ANALOG_RA3_REF);
   set_adc_channel(0);
   // works properly
      temp_in = 0;
         delay_ms(50);
I still need help reading the output. I'm using the ICD-S and MPLAB IDE program. Is there a way to just test the output using a printf? If so how can I get it to show the ouput through the program? Thanks.
