PIC10F206 loses data after sleep?
mcafzap
PostPosted: Thu Mar 10, 2005 3:10 pm     Reply with quote
I have a problem where I put the PIC to sleep, but only want it to do anything one third of the time. With the 12F629 this is no problem, so I'm beginning to suspect the 10F...
#include <10F206.h>
#Fuses NOMCLR,NOPROTECT,WDT
#use fast_io(B)
void shortbeep(void);
void initialise(void);
#byte GPIO = 6
#bit GP0= GPIO.0
#bit GP1= GPIO.1
#bit GP2= GPIO.2
#bit GP3= GPIO.3
#byte CMCON0 = 0x07
#bit CMPOUT = CMCON0.7
int8 count;
   initialise();
   While(1){
      if (CMPOUT){            // Outside apparently...
         if (count > 2) {
         shortbeep();   //beep if required.
         count = 0;
   sleep();
   initialise();
   count++;
} //end main
//******************************* end main program *************************************
void initialise(void) {
   GPIO = 0x00;
#asm
   movlw 0x09  //Bits 0 & 3 inputs
   TRIS GPIO
// Disable wake-up on pin change, enable weak pull-ups,
// Timer0 source internal, L to H
// Prescaler to WDT, max division 2304mS
   movlw 0x8F
   OPTION
#endasm
// no comparator output,
   CMCON0 = 0x7B;
// Piezo element on GPIO bits 0 and 1
int8 t, j;
t = GPIO & 0x09;
for(j=0; j<=250;j++)
   GPIO = t | 0x02;
   Delay_Us(120);
   GPIO = t | 0x04;
   Delay_Us(110);
GPIO = t;
Now if I remove the
         if (count > 2) {
All is well, suggesting a loss of data from sleep period to sleep period. The supply is fairly heavily decoupled with a 1uF ceramic right under the PIC, along with a 100uF Al electrolitic.
Am I doing something particularly stupid that one of you can spot?
FWIW the compiler is version 3.206
Steve
PostPosted: Thu Mar 10, 2005 3:52 pm     Reply with quote
The "wake-up from sleep" behavior is different between the two devices.
Compare the data sheets in that area.
mcafzap
PostPosted: Thu Mar 10, 2005 4:49 pm     Reply with quote
Good thinking PCM, thank-you.
For anyone's interest, the 10F series generates a standard reset on watchdog timeout whether or not it is in sleep mode, this means that the line
   count++;
will never be executed.
In fact because of this behaviour the code can be simplified: remove the while(1) loop because the of the hidden 'SLEEP' instruction, initialise() need only be in line since it too would not be reached.
Steve
