detecting rising edges on pins RA0 and RA1
SlimG
PostPosted: Tue Mar 08, 2005 3:45 pm     Reply with quote
Hi folks I trying to detect the rising of 2 square waves each been applied to pin RA0 and Pin RA1.(PIC16F873)
Below are examples of the 2 codes:
N.B. the code are NOT to the letter just to give an idea of what im doing
If (pinA0 =1){ // detecting a 1 state instead of rising edge
bla bla
else {
if (pinA1=1){ //detecting a 1 state instead of rising edge
bla bla
the above doesn't give a consistent answer because it check the state and not the rising edge
SECOND EXAMPLE
sample_1=pinA0;
sample_2=pinA0;
sample_3=pinA1;
sample_4=pinA1;
if (sample_1==0 && sample_2==1) //detecting rising edge 0 to 1
bla bla;
{ if (sample_3==0 && sample_4==1) //detecting rising edge 0 to1
bla bla
the second example doesn't work at all!
Does anybody have suggestions pls????!!!! It is my final year project.
fuzzy
PostPosted: Tue Mar 08, 2005 4:09 pm     Reply with quote
you can try to store the status of one port in the last bit of a byte. every cicle you shift left this byte and store the new status of port. if first and second bit are equal there isn't a change. instead in the first is high and the second low you have a rising edge and viceversa.
you can do it oalso using 2 variables one fore the actual status and the another to store the previous one. and then you can compare them.
bluetooth
PostPosted: Tue Mar 08, 2005 4:15 pm     Reply with quote
SlimG:
What you want to do is best done with hardware.... while you can do what you want, you'll tie up the PIC spinning tightly looking at the two square waves, and if you take time to do anything else, you'll absolutely lose timing accuracy or worse, miss transitions all together.
The PIC you're using has a "change detector" on pins RB4 through RB7.
Why not hook up to those pins and use interrupts to achieve your goal?
Good luck with your final year! Smile
