John_Rio
Joined: 22 Jan 2005 Posts: 12 Location: Rio de Janeiro, Brazil
Decoder for B&O remote control. |
Posted: Fri Feb 25, 2005 2:10 pm |
I was looking a long time for something like this, but ended up doing it by myself.
I anybody wants it, here it is.
The input B0 is connected to a infrared link receiver (B&O product) that gives 5 V pulses.
I did not try it with a standard infrared receiver.
The code is simple and can be adjusted to your own needs.
When a key is pressed on the remote, the PIC sends a string containing the 16 byte code. (send as A,B,C) since each "bit" has 3 states.
John (Still in Denmark)
#include <18F252.h>
#device ICD=TRUE
#device adc=8
#fuses NOWDT,WDT128,EC_IO, NOPROTECT, NOOSCSEN, BROWNOUT, BORV20, NOPUT, STVREN, NODEBUG, LVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,enable=PIN_C5)
INT8 Counter=0;
INT16 time[25];
INT1 Received=0;
INT1 fejl;
INT8 Code[17];
#int_EXT
EXT_isr()
time[counter]=get_timer0();
set_timer0(0);
Counter++;
IF (counter==22)Received=TRUE;
#int_TIMER0
TIMER0_isr()
counter=0;
void Check_Start_Stop()
fejl =0;
IF (time[1]<5250 || time[1]>10500) {fejl=1;Break;}
IF (time[2]<5250 || time[2]>10500) {fejl=1;Break;}
IF (time[3]<33500 || time[3]>42000) {fejl=1;Break;}
IF (time[4]<5250 || time[4]>10500) {fejl=1;Break;}
IF (time[21]<26000 || time[21]>33500) {fejl=1;Break;}
void Check_Code()
INT8 i;
For (i=0;i<=15;i++)
IF (time[i+5]<5250) fejl=1;
IF (time[i+5]>5250) code[i]='A';
IF (time[i+5]>10500) code[i]='B';
IF (time[i+5]>18250) code[i]='C';
IF (time[i+5]>26000) fejl=1;
void read_remote()
Check_start_stop();
IF (!fejl)
check_code();
IF (!fejl)
code[16]=0x00;
Output_High(PIN_C5);
Delay_us(500);
printf(code);
printf("\r");
received=0;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
enable_interrupts(INT_EXT);
DO
IF (received) read_remote();
WHILE (true);
John_Rio
UPS. A small code mistake. |
Posted: Fri Feb 25, 2005 2:42 pm |
The code in Check_Start _Stop is wrong.
It has to be:
Sorry about that.
John
treitmey
Posted: Mon Feb 28, 2005 10:00 am |
John_Rio
Done the edit. |
Posted: Tue Mar 01, 2005 1:56 pm |
Sorry about the mistake.
I didnt know posts could be edited after posting.
I can though not find a way to delete my correction post !!
John |
Mark
Re: Done the edit. |
Posted: Tue Mar 01, 2005 2:35 pm |
John_Rio wrote: | Hi,
John |
Just edit it and delete the text. |
