tcp/ip lean: miniature web server
feiutm9898
PostPosted: Tue Jun 01, 2004 11:23 am     Reply with quote
Hi.
I have problem to compile source code come with tcp/ip lean books.
I use pcm version 3.187 .
I fail to compile the source code for tcplean/pcm/picweb.c at CDROM
This source code is the first version of TCP/IP Lean for SLIP communication. Not "CHIPWEB" version.
The error is "invalid type conversion" at the variable
Do you try it? And can provide updated source code for me.
please help me!
the error at red color line
if (match_byte(0x45) && skip_byte() && // Version, service
get_word(iplen) && skip_word() && // Len, ID
skip_word() && skip_byte() && // Frags, TTL
get_byte(ipcol) && skip_word() && // Protocol, checksum
get_lword(remote.l) && get_lword(local.l) &&// Addresses
checkhi==0xff && checklo==0xff)
Chas
PostPosted: Tue Jun 01, 2004 11:56 am     Reply with quote
Check the FAQ for the compiler at the link below, and start with that:
http://www.ccsinfo.com/faq/?34
PostPosted: Tue Jun 01, 2004 12:36 pm     Reply with quote
A similar problem was discussed on the Microchip forum.
One person, alesan, said he fixed the problem, though
he didn't say how. You could email him for the answer
if you join the Microchip forum.
http://forum.microchip.com/tm.asp?m=30649#35964
PedroMoreira
PostPosted: Sun Mar 06, 2005 12:53 pm     Reply with quote
I have the same problem...
anyone here can explain me how to fix this problem!!!!!?????
PostPosted: Sun Mar 06, 2005 10:52 pm     Reply with quote
The problem is the definition of data type LWORD for very old CCS version.
try ... get_lword(&remote.l) && get_lword(&local.l)
or ... get_lword(&remote) && get_lword( &local )
the argument of function get_lword() should be a pointer,
i.e. the ADDRESS of the variable
check p16_drv.h and p16_web.c, you will see ...
BOOL get_lword(LWORD &lw);
typedef union // Longword definition (not a native type)
BYTE b[4];
WORD w[2];
BYTE l;
} LWORD;
Best wishes
