Clearing Serial Rx Data
ronald
PostPosted: Wed Mar 02, 2005 2:47 am     Reply with quote
i'm using getting GPS signals to my PIC 18F452 and am using a PIC C compiler.
the problem i'm experiencing is that if i execute a code that is too lengthy between the sequential retreiving of the GPS data (once every second), then my system hangs and cannot get the next set of data.
i understand from a friend the way about this is probably to clear the serial Rx buffer just before i read from it. Will anyone be able to advice me if this is correct and what code/function should i use to implement this.
Thanks a lot
Re: Clearing Serial Rx Data
PostPosted: Wed Mar 02, 2005 4:53 am     Reply with quote
ronald wrote:
Thanks a lot
Add the 'ERRORS' command to the #use RS232 setup.
The problem is that if the internal hardware buffer is not read in time, the UART, sets it's 'overflow' flag, and will stop receiving characters till this is cleared. Just reading the buffer, will not clear this. The 'ERRORS' command, tells the compiler to automatically clear this flag, and if you then read the buffer, things will carry on working. :-)
