Guest Guest
Newbee write_eeprom question |
Posted: Sat Feb 26, 2005 9:21 am |
Hi to all!
I want to write integers into memory and after ich button click i want to encrease the value in the memory, and then print the value out..
address 0x2100;
short int value;
value=0;
if (input(PIN_D1))
value++;
write_eeprom(address,value)
What do i have to add so that this can work...
p.s. Now is the value 0 and wenn you click on same button again the memory value is the same. Why? |
Humberto
Posted: Sat Feb 26, 2005 10:44 am |
Guest wrote:
You define:
short int value;
The size of a short int in CCS is a single bit. (0-1)
So you need to replace it by:
int8 value; // range (0-255)
write_eeprom(address,value) // is plain text
write_eeprom(address,value); // is a proposition
int8 value;
int8 value_stored;
if (input(PIN_D1)) // Need a HIGH
{ // Need to debounce
value++;
value_stored = read_eeprom(address);
printf("\r\n %D", value_stored);
This code is just what you ask. Not the best way to do it.
Read and practice the examples provided by CCS.
Humberto |
Guest Guest
Posted: Sun Feb 27, 2005 7:09 am |
Thank you i will try it!
I found ex_intee.c file as some example from CCS.
Whats the "best way" to do this ? |
Posted: Sun Feb 27, 2005 7:27 am |
Note also, that an address of '0x2100', is not legitimate for the 'write_eeprom' function. This function talks to the eeprom data memory, which is only 256 bytes long (addresses 0..255). This memory is 'mapped' into the programming space (when you are programming the chip in an external programmer), at address 0x2100 (on some chips - the 16F family in general), but you would only need an address of '0' to talk to this byte.
Humberto
Posted: Sun Feb 27, 2005 8:58 am |
Guest wrote:
The code I posted was only to "satisffy" this:
To "see" how run this code you need to apply a HIGH in PIN_D1 through
a switch or something else. If you do it it with a mechanical switch, you
will realize that every time you press the switch the counter value will
have more than 1 increment because the "bounce" of the internal contacts
of the switch.
To override this will be necesary to add a delay to "wait" until the contacts
stop bouncing and after that you can validate a "steady state". To
implement a debounce software technique you will see that fortunatelly
there are different ways so your question:
Doesnīt have a single answer, that is one of the reason why C language
is still alive, because it has all that you need to develop what you want
following a logic criteria, depending of your knowlede and creativity. I
have some devices that I made 7 years ago, they are still running fine,
but when I read the code that I wrote, I realize that it need some changes
here and there, and that such function I would do it in that way, etc, etc.
All the codes are perfective, improvable and upgradable.
Donīt worry, every time I read a code I ask myself:
"Whats the "best way" to do this ?"
Humberto |
Guest Guest
Posted: Sun Feb 27, 2005 4:34 pm |
This is the code am using. I have listed questions under code part.
#define countdown hour
int sec=0,hour=10,day=5,dayset=0;
int1 debounce=0;
#int_TIMER1
TIMER1_isr()
set_timer1(0xF000);
secs++;
if (secs==3600)
secs=0;
hours--;
if (hours==24)
hours=0;
days--;
if (countdown==dayset)
disable_interrupts(global);
output_high(PIN_D6);
for (secs=0;secs<60;secs++)
int8 iVal=0, iValS, brTab, brTabS;
port_b_pullups(TRUE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_2);
enable_interrupts(global);
//-- > CONFIRMATION BUTTON-------
if(INPUT(PIN_D6))
brTab++;
write_eeprom(f_e_a,100);
//-- close button access for 10 hours
brTabS=read_eeprom(f_e_a);
printf(displayPUTC,"%D",brTabS);
displayDO();
//---FIRST PART OF SECOND BUTTON is activ until first CONFIRMATION click------
if (INPUT(PIN_D7) && read_eeprom(b_pr)==00)
printf(displayPUTC,"0");
displayDO();
write_eeprom(b_pr,1);
iValS=read_eeprom(b_pr);
if (INPUT(PIN_D7) && read_eeprom(b_pr)==01)
//- show rest of countdown time
printf(displayPUTC,dayset); //-- not formated
displayDO();
write_eeprom(b_pr,2);
if (INPUT(PIN_D7) && read_eeprom(b_pr)==02)
//-- show number of clicks on confirmation button
printf(displayPUTC,read_eeprom(brTab));
displayDO();
} // --while
q1.) When you click first time on confirmation button the eeprom value
is encreasing without stop.
q.2) Why can't i solve this tree state button clicks(second button) like in the example above. Do you have better idea to solve this? |
Humberto
Posted: Sun Feb 27, 2005 6:05 pm |
1)We donīt know your hardware. Pull up/down resistor? etc.
2)A proposition like
if(INPUT(PIN_D6))
your stuff
is expecting a HIGH whenever you push the switch, and when you
release it the input PIN_D6 must be LOW. Try to solve this before
take any action.
3)Divide your code in small tasks, test that each function is running
properly and then join all together according to the function criteria.
Pls try this practice for yourself.
Humberto |
Guest Guest
Posted: Mon Feb 28, 2005 3:07 am |
All of them are pull UP resistors on 16F877 chip...
Im using simulator thefore i can make changes i view them in real time , but i just need to now what is the "right way" to solve this. Thefore i need some help in this part... |
Humberto
Posted: Mon Feb 28, 2005 4:25 am |
1) Only PORTB has pull up resistors. To activate you must enable them.
2) You have the switch connected in PORTD.
3) According to your code you need a pull DOWN. Not a pull UP resistor.
I assume you have a pull DOWN resistor (aprox 10K) in PIN_D6 and a
switch wired to +5V and try this:
if(input(PIN_D6)) // means if INPUT PIN_D6 is HIGH....
output_high(PIN_D1);
output_low(PIN_D1);
This is basic schooling, try to practice and understand the simplest
examples and get some books to learn from.
This way is not easy for you nor for us.
Best wishes,
Humberto |
