flip
Battery supply for PIC18F458 |
Posted: Thu Feb 24, 2005 12:13 pm |
I want my PIC18f458 to run on batteries, (two AA's (3V)), does anyone know what kind of circuit I will need or the best way to implement this?
I was told I will need a voltage regulator, to make the DC constant (even though I thought DC was constant), but I am not to sure what kind of voltage needs to supplied to the voltage regulator.
So if anyone can make a suggestion that would be great. |
Posted: Thu Feb 24, 2005 12:36 pm |
If you're going to run off two 1.5v batteries, that's 3v, and you'll need
to the the 18LF458. The regular "F" chip won't run below 4.2v, according
to the data sheet.
I did a project which used a DC-DC boost converter. It ran off two
AA cells, so it started with a 3v input, and declined to about 2v over
the useful battery life. It put out a constant +3.3v to the 18LF458.
I used a T.I. TPS61107 for this.
But this is probably too complex for your project. It's probably easier
to just use the "LF" PIC. Also, you should run it at 4 MHz if you run
it off two batteries (which decline in voltage). See Figure 27-3 in
the 18F458 data sheet to see why I suggest this. |
