This is another bug in CCS? (3.212)
Zampar
PostPosted: Thu Feb 24, 2005 3:54 pm     Reply with quote
i'm is working in a menu and i have a big problem:
whats have wrong in a logic because I need press two times the key 4 to view the next window.
the function ajuste_dispositivos() retorn void.
   While (true)
         for(;((Nova_Tecla) && (Tecla == 4)); menu_p++) // MENU PRINCIPAL
            disable_interrupts(int_TIMER1);
            Nova_Tecla = 0;
                  if (menu_p < maximo_dispositivos)
                     ajuste_dispositivos(menu_p);
                   if (menu_p == maximo_dispositivos)
                      ajuste_relogio();
regards
Zampar
(sorry for my English, but I speak and write only in Portuguese)
Saudações ao BRASIL!!
Humberto
PostPosted: Thu Feb 24, 2005 4:20 pm     Reply with quote
Hola Zampar,
1) I guess that it´s too early to suppose such error as a bug compiler. Confused
2) With the code you posted we don´t have enough information to test
and reproduce the error.
3) We doesn´t know the previous state of your variables to analize the
code.
Saludos Very Happy
Humberto
Hans Wedemeyer
Re: This is another bug in CCS? (3.212)
PostPosted: Fri Feb 25, 2005 2:57 pm     Reply with quote
   While (true)
            Nova_Tecla = 0;
                      ajuste_relogio();
regards
Zampar
Try using if() and not for() It will be easier to read your code. There is no glory in making code difficult to read :-)
Assuming variables Nova_Tecla and Tecla are zero, then if Nova_Tecla is true Tecla must be equal to 4 before the code will do any thing.
So everytime (Nova_Tecla && Tecla == 4) is true the code will do something.
The question is When or what ( I suspect a key press) increments Tecla ?
Any if Tecla started at 0 and it increments by 1 then it will take FOUR (4) actions, and you say it takes two !
Which makes me think you may also have a debounce problem wherever Tecla is being handled.
This should be easier to read….
Nova_Tecla = 0;
Tecla = 0;
while (true)
if( Nova_Tecla && Tecla == 4) // then do something
Nova_Tecla = 0;
ajuste_relogio();
menu_p++;
I'm not saying the compiler is perfect, however it's too easy to blame it... I recommend you use a better easier to read syntax. for() is for doing something a number of times while a conditions is not true.
In this case I think your code needs to test two variables to see if they are true and then do one thing, in which case if() is the better choice.
Good luck
