How to use #device WRITE_EEPROM=ASYNC
GUEST
PostPosted: Tue Mar 01, 2005 12:53 pm     Reply with quote
I do not want to stop interrupting in the middle of writing.
It uses and it is thought the one at such time.
However, whether goodness when using it very is not understood. Please
teach someone.
PostPosted: Tue Mar 01, 2005 3:38 pm     Reply with quote
To use it, just add the line shown below to your program.
Make sure you put the line immediately below the main "#include" line
as shown in this example.
#include <16F877.H>
#use delay(clock = 4000000)
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#int_ext
void int_ext_isr(void)
char c;
c = 0xAA;
write_eeprom(0, 0x55);
GUEST
PostPosted: Tue Mar 01, 2005 9:29 pm     Reply with quote
Thank you very much!
The result like hope it was obtained.
From ahead to instruction wanting it very much
Hereafter, please hold out.
