How to use the fonction with const char pointer in parameter
Dany
PostPosted: Wed Feb 23, 2005 2:50 am     Reply with quote
I'm working on 18F4620 and with CCS compiler version 3.219
I have created the the fonction with the const char * in parameter. But the compiler didn't accept.
const char MAIN_MENU[9][14] ={{"MENU 1 "},
{"MENU 2 "},
{"MENU 3 "},
{"MENU 4 "},
{"MENU 5 "},
{"MENU 6 "},
{"MENU 7 "},
{"MENU 8 "},
{"MENU 9 "}};
void MEN_GestionListeDeroulant(const char * ListeDesChoix)
strcpy(buf_DisplayLine_L1, ListeDesChoix);
LCD_voidPutString(0x80, &buf_DisplayLine_L1[0], 14);
MEN_GestionListeDeroulant(&MAIN_MENU[0][0]);
The compiler is tell me an error on this function.
Thanks.
Dany Confused
PostPosted: Wed Feb 23, 2005 4:21 am     Reply with quote
The compiler does not support pointers to constant values. Hence you will need either to move the variable into RAM, where pointers can be used, or consider passing the function just the index of the array, and with the array as a global variable, then do the array access inside the function.
