1 bit shifting to right on 3-wire serial communication. why?
regall
PostPosted: Sat Feb 19, 2005 3:39 am     Reply with quote
what is the reason of shifting 1 bit to the right on 3-wire serial communication?
#fuses HS,NOWDT
#use delay (clock=8000000)
#use RS232(BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7, STREAM=COM1)
data=fgetc(COM1);
spi_write(data);
spi_read();
delay_ms(10);
data1=spi_read(0);
data1=data1<<1; //solving the problem like that
printf("The Response=%x\n\r",data1);
TSchultz
PostPosted: Sat Feb 19, 2005 8:22 am     Reply with quote
I suspect you may be using the wrong signaling with your SPI. You can setup the SPI for any of the 4 modes. Using the wrong mode can cause a problem like this. Also it looks like you are shifting left.
What is the device you are communication to with SPI?
How have you setup the SPI?
We need this information to try and help you out.
