Why when I got a data is problem?
NewSpace
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
PostPosted: Sun Feb 20, 2005 1:12 am     Reply with quote
Dear Master~!
Hi~
When I got a ADC data is problem
It's about 30-40 is different....
1st 129
2nd 135
3th 110
4th 140
That's same volte
and float data is can't operation.
Please check my code....
Thank you~!
#include<16F874.h>
#device pic16f874 *=8 adc=10
#use rs232(baud=19200,parity=N,xmit=PIN_C4,rcv=PIN_C5)//,ERRORS,stream = PORT1)
#zero_ram
// A0 (02) = [AD] humidity (0.8 - 3.9 V)
// A1 (03) = [AD] Temp (0.0 - 5.0 V)
// A2 (04) = [AD] Vref - (0.8 V)
// A3 (05) = [AD] Vref + (3.9 V)
// A4 (06) =
// A5 (07) =
int16 value = 0;
float humi = 0 , temp = 0;
void Read_Humity()
   setup_adc_ports(RA0_ANALOG_RA3_RA2_REF);
   set_adc_channel(pin_a0);
   delay_us(10);
   value = read_adc();
   setup_adc( ADC_OFF );
   humi = ((value*5)/1023);
   printf("%c%c%c",0xa1,0,1);
   printf("%cAD=%04lu Humi=%02f %c",0xa2, value, humi, 0);
void Read_Temp()
   setup_adc_ports(RA0_RA1_RA3_ANALOG);
   set_adc_channel(pin_a1);
   delay_us(10);
   value = read_adc();
   temp = ((value*5)/1023);
   printf("%c%c%c",0xa1,0,2);
   printf("%cAD=%04ld Temp=%02f%c",0xa2, value, temp, 0);
   ext_int_edge(0,L_TO_H);
   enable_interrupts(int_ext);
   enable_interrupts(global);
                        // 7 6 5 4 3 2 1 0
   set_tris_a(0x3F);    //     I I I I I I
   set_tris_b(0xFF);    // I I I I I I I I
   set_tris_c(0x00);    // O O O O O O O O
   set_tris_d(0x00);    // O O O O O O O O
   set_tris_e(0xFF);    //           I I I
   output_c(0x00);
   output_d(0x00);
   output_e(0x00);
      Read_Temp();
      Read_Humity();
Hello~?
This is South KOREA
My name is Sanghyouk Kim But Call me Nick
Sorry I'm poor English
libor
PostPosted: Sun Feb 20, 2005 6:23 am     Reply with quote
channels are numbered 0-12, so use
set_adc_channel(0);   //for AN0
set_adc_channel(1);   //for AN1
instead PIN_A0, PIN_A1, these PIN_XX are defined to some higher values, you might have had luck, it got truncated to the lower bits, so this is not causing your problem.
If you get valid readings, but the values are floating, then try to increase the wait time in the delay_us to let thing settle.
It can be a hardware design problem also. Noise can cause these problems, is your VREFs of a proper impedance? (put capacitors on your Vrefs) What is the impedance of your analog signals? If you have a slow moving signal anyway, you can put a capacitor on your signal to filter noise.
To lessen digital noise in the PIC itself, you can also consider putting the PIC into sleep during conversion with (but you should have smoother readings without this sleep thing also)
read_adc(ADC_START_ONLY);
sleep();
value=read_adc(ADC_READ_ONLY);
