Interrupt
bhyatyab
Interrupt
PostPosted: Fri Feb 18, 2005 3:26 am     Reply with quote
Hi
I need some help with interrupts. I want a delay. I want to use an interrupt on pin change to break this delay - RB0.
Please can any one help me as i don't know how to use it. Thanks
#include <18F452.h>
#device ICD=TRUE
#device adc=8
#fuses NOWDT, WDT128, HS, NOPROTECT, NOOSCSEN, BROWNOUT, BORV20, PUT, STVREN, DEBUG, LVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9)
#include <STDLIB.H>
void main(){
/* INITIALISATION SECTION
/* Part of Bootup Sequence. All peripherals
/* are configured and activated.
delay_ms(10000); //always do this
while(input(PIN_B0));
while(!input(PIN_B0));
output_high(PIN_B3); //clear
output_low(PIN_B3);
EdWaugh
hi
PostPosted: Fri Feb 18, 2005 5:14 am     Reply with quote
you perhaps want to rty something like this
short flag;
main()
disable_interrupts(GLOBAL);
enable_interrupts(INT_EXT);
flag=0;
while(!flag)                 // this means while flag=0 but is faster
    //do what ever you want here
    // this will delay until the rising edge
#int_ext1                   // this is for 18f252 check your valid interrupt labels
isr()
 flag = 1;
this should give you the idea
ed
