TEK66TIM
18lf4620 resets on it's own |
Posted: Tue Sep 26, 2006 3:06 pm |
Hello all,
I have a 18lf4620 and it resets on it's own. I used the reset_cause() func and it tells me the WDT is responsible. I have NOWDT set in the fuses. Thanks in advance for any help, here is the code: Code: | #include <18f4620.h>
#include <stdlib.h>
#fuses NOLVP, NOWDT, EC_IO
#use delay (clock=25000000)
#use rs232 (baud=115200, xmit=PIN_E1, rcv=PIN_E0)
void main (void)
int8 data;
int8 res_data;
delay_ms (2000);
res_data = restart_cause ();
if (res_data > 0)
printf ("reset cause = %u", res_data);
putc (0x0D);
putc (0x0A);
do
if (kbhit ())
data = getc ();
printf ("data = %x", data);
putc (0x0D);
putc (0x0A);
while (1);
Posted: Tue Sep 26, 2006 3:18 pm |
1. What's your compiler version ?
2. What value is displayed for the restart cause ? |
TEK66TIM
Posted: Tue Sep 26, 2006 3:25 pm |
Thanks for the quick reply, I think I found my problem, I use the Melabs Epic programmer and just updated the programmer software. The config programming was turned off, I set this to on and re-programmed the chip, it looks like it's working. |
