Jerry Guest
Structure Help |
Posted: Tue Feb 15, 2005 8:18 pm |
This is some sample code that I have found on web.
Can I define a structure this way with this PCH compiler.
Getting error #27 Expression must evaluate to a constant.
This is a portion of code.
#include <18F252.h>
#fuses hs, nowdt, noprotect, nolvp, put, NOOSCSEN
#device *=16 icd=TRUE
#device adc=8
#define FONT_COUNT 1
const unsigned char dot_font_table[] = {
/* ' ' charwidth: 2 */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
/* '!' charwidth: 2 */
0x00, /* [ ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x00, /* [ ] */
0x80, /* [* ] */
0x00, /* [ ] */
const unsigned char font_width_table[] = {
2, /* ' ' */
2, /* '!' */
typedef struct
char store_width; /* font storage width in bytes */
char font_height; /* font height for storage */
char *font_table; /* font table start address in memory */
char fixed_width; /* fixed width of font. If zero */
/* then use the width table. */
char *width_table; /* variable width table start address */
char charmap_beg; /* start ascii offset in table */
char charmap_end; /* end ascii offset in table */
char char_def; /* code for undefined char code */
} FONT_DEF;
FONT_DEF fonts[FONT_COUNT] = {
{1, 7, dot_font_table, 0, width_width_table,' ','!','!'}};
main()
Thanks in advance for any help.
Jerry |
Mark
Posted: Tue Feb 15, 2005 9:35 pm |
No pointers to constants allowed in CCS. |
Jerry Guest
Posted: Tue Feb 15, 2005 9:55 pm |
What would be the correct syntax if I don't use the constants for tables.
Jerry |
Mark
Posted: Tue Feb 15, 2005 10:13 pm |
Like this:
#include <18F252.h>
#device adc=8
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x00, /* [ ] */
0x80, /* [* ] */
0x00, /* [ ] */
2, /* ' ' */
2, /* '!' */
typedef struct
} FONT_DEF;
1, 7, dot_font_table, 0, font_width_table,' ','!','!'};
main()
Jerry Guest
Posted: Tue Feb 15, 2005 10:24 pm |
Hey Mark;
I get the same error ???
Now what
Thanks Jerry |
Mark
Posted: Wed Feb 16, 2005 8:22 am |
Did you copy and paste the code I posted? It compiles just fine for me. |
Jerry Guest
Posted: Wed Feb 16, 2005 10:46 pm |
Thanks |
