Structure Help
Jerry
Structure Help
PostPosted: Tue Feb 15, 2005 8:18 pm     Reply with quote
This is some sample code that I have found on web.
Can I define a structure this way with this PCH compiler.
Getting error #27 Expression must evaluate to a constant.
This is a portion of code.
#include <18F252.h>
#fuses hs, nowdt, noprotect, nolvp, put, NOOSCSEN
#device *=16 icd=TRUE
#device adc=8
#define FONT_COUNT 1
const unsigned char dot_font_table[] = {
      /* ' ' charwidth: 2 */
      0x00,    /*  [  ]  */
      0x00,    /*  [  ]  */
      0x00,    /*  [  ]  */
      0x00,    /*  [  ]  */
      0x00,    /*  [  ]  */
      0x00,    /*  [  ]  */
      0x00,    /*  [  ]  */
      /* '!' charwidth: 2 */
      0x00,    /*  [  ]  */
      0x80,    /*  [* ]  */
      0x80,    /*  [* ]  */
      0x80,    /*  [* ]  */
      0x00,    /*  [  ]  */
      0x80,    /*  [* ]  */
      0x00,    /*  [  ]  */
const unsigned char font_width_table[] = {
       2, /* ' ' */
       2, /* '!' */
    typedef struct
       char store_width;            /* font storage width in bytes */
       char font_height;            /* font height for storage */
       char *font_table;            /* font table start address in memory */
       char fixed_width;            /* fixed width of font. If zero */
                                    /* then use the width table. */
       char *width_table;            /* variable width table start address */
       char charmap_beg;         /* start ascii offset in table */
       char charmap_end;         /* end ascii offset in table */
       char char_def;            /* code for undefined char code */
    } FONT_DEF;
FONT_DEF fonts[FONT_COUNT] = {
            {1,  7, dot_font_table, 0, width_width_table,' ','!','!'}};
main()
Thanks in advance for any help.
Jerry
Mark
PostPosted: Tue Feb 15, 2005 9:35 pm     Reply with quote
No pointers to constants allowed in CCS.
Jerry
PostPosted: Tue Feb 15, 2005 9:55 pm     Reply with quote
What would be the correct syntax if I don't use the constants for tables.
Jerry
Mark
PostPosted: Tue Feb 15, 2005 10:13 pm     Reply with quote
Like this:
#include <18F252.h>
#device adc=8
      0x00,    /*  [  ]  */
      0x00,    /*  [  ]  */
      0x00,    /*  [  ]  */
      0x00,    /*  [  ]  */
      0x00,    /*  [  ]  */
      0x00,    /*  [  ]  */
      0x00,    /*  [  ]  */
      0x00,    /*  [  ]  */
      0x80,    /*  [* ]  */
      0x80,    /*  [* ]  */
      0x80,    /*  [* ]  */
      0x00,    /*  [  ]  */
      0x80,    /*  [* ]  */
      0x00,    /*  [  ]  */
       2, /* ' ' */
       2, /* '!' */
    typedef struct
    } FONT_DEF;
            1,  7, dot_font_table, 0, font_width_table,' ','!','!'};
main()
Jerry
PostPosted: Tue Feb 15, 2005 10:24 pm     Reply with quote
Hey Mark;
I get the same error ???
Now what
Thanks Jerry
Mark
PostPosted: Wed Feb 16, 2005 8:22 am     Reply with quote
Did you copy and paste the code I posted? It compiles just fine for me.
Jerry
PostPosted: Wed Feb 16, 2005 10:46 pm     Reply with quote
Thanks Very Happy
