Darren Logan Guest
Is it possible to pass a stream to a function? |
Posted: Sun Feb 23, 2003 4:33 am |
It is possible to pass a Stream identifier to a function?
It would save a lot of code space for me if this was possible.
Currently, I have to determine which serial port (i have 2) I need to send data out of thus (example):
void sendit(int whichport) {
if(whichport==1) {
fprintf(port1,"calling from port 1");
if(whichport==2) {
fprintf(port2,"calling from port 2");
what i'd really like to do is:
fprintf(whichport,"sending from port \%u",whichport);
What i've done doesn't work, im wondering whether a) I've done something wrong or b) You simply can't do it this way?
Answers on a postcard to "Save the ROM competition", FrustratesVille, UK
Cheers,
Darren
Original Post ID: 12031 |
Mark
Re: Is it possible to pass a stream to a function? |
Posted: Sun Feb 23, 2003 10:04 am |
You could you sprintf to put the data in a string and then write out to the port of choice
or
the printf command allows you to specify a function as the first parameter. The default is putc(), however, you could make your own function in which you specify the stream and then that function outputs accordingly.
:=Hello,
:=It is possible to pass a Stream identifier to a function?
:=It would save a lot of code space for me if this was possible.
:=Currently, I have to determine which serial port (i have 2) I need to send data out of thus (example):
:=void sendit(int whichport) {
:=if(whichport==1) {
:=fprintf(port1,"calling from port 1");
:=if(whichport==2) {
:=fprintf(port2,"calling from port 2");
:=what i'd really like to do is:
:=fprintf(whichport,"sending from port \%u",whichport);
:=What i've done doesn't work, im wondering whether a) I've done something wrong or b) You simply can't do it this way?
:=Answers on a postcard to "Save the ROM competition", FrustratesVille, UK
:=Cheers,
:=Darren
Original Post ID: 12034 |
Darren Logan Guest
Posted: Sun Feb 23, 2003 11:04 am |
Mark,
Thanks. I like the sound of 2nd idea (printf) but admit to be a little under-skilled in this area.
Could you post typical code please ????
Thanks,
Darren
Original Post ID: 12036 |
Mark
Posted: Sun Feb 23, 2003 2:04 pm |
void myputc(char somedata)
if(whichport==1)
fputc(port1,somedata);
fputc(port2,somedata);
void main
whichport = 1;
printf(myputc,"sending from port \%u",whichport);
whichport is a global in this case.
Regards,
Mark
:=Mark,
:=Thanks. I like the sound of 2nd idea (printf) but admit to be a little under-skilled in this area.
:=Could you post typical code please ????
:=Thanks,
:=Darren
Original Post ID: 12039 |
Darren Logan Guest
Posted: Mon Feb 24, 2003 6:59 am |
Thanks Marks, much appreciated. I'll give it a whirl.
This should save a fair bit of space as currently I've got duplicate fprintf's sending the same data only out different ports.
Cheers,
Darren
Original Post ID: 12051 |
