USB 16C765
Stephanfo
USB 16C765
PostPosted: Sun Feb 06, 2005 1:20 pm     Reply with quote
I'have a matter with USB_HID_DESC[], because windows can't arrive to recognise the HID Gamepad.
I started to copy ex_usb_mouse.c from example directory to my project, and once compiled and my device (16C765) programmed, the mouse turn in round, and everything is ok.
I tried to write my own USB_HID_DESC to make a joystick according to microsoft advise, and USB.ORG HID TABLE, to directly use windows driver. However, my usb description don't work cause windows recognise it as a "HID Mouse", and in the peripheric description "This peripheric don't want to start".
I don't know if the mater is in my USB_HID_DESC or if it come from another thing I didn't change correctly (I have just changed the HID Description).
Below, my usb description. Please, help me, I try to solve my problem for 2 weeks.
   const char USB_HID_DESC[] = {
    0x05, 0x01,                    // USAGE_PAGE (Generic Desktop)
    0x15, 0x00,                    // LOGICAL_MINIMUM (0)
    0x09, 0x04,                    // USAGE (Joystick)
    0xa1, 0x01,                    // COLLECTION (Application)
       0x05, 0x02,                    //   USAGE_PAGE (Simulation Controls)
       0x09, 0xbb,                    //   USAGE (Throttle)
       0x15, 0x81,                    //   LOGICAL_MINIMUM (-127)
       0x25, 0x7f,                    //   LOGICAL_MAXIMUM (127)
       0x75, 0x08,                    //   REPORT_SIZE (8)
       0x95, 0x01,                    //   REPORT_COUNT (1)
       0x81, 0x02,                    //   INPUT (Data,Var,Abs)
       0x09, 0x01,                    //   USAGE (Pointer)
       0xa1, 0x00,                    //   COLLECTION (Physical)
          0x09, 0x30,                    //     USAGE (X)
          0x09, 0x31,                    //     USAGE (Y)
          0x95, 0x02,                    //     REPORT_COUNT (2)
       0xc0,                          //   END_COLLECTION
       0x09, 0x39,                    //   USAGE (Hat switch)
       0x25, 0x03,                    //   LOGICAL_MAXIMUM (3)
       0x35, 0x00,                    //   PHYSICAL_MINIMUM (0)
       0x46, 0x0e, 0x01,              //   PHYSICAL_MAXIMUM (270)
       0x65, 0x14,                    //   UNIT (Eng Rot:Angular Pos)
       0x75, 0x04,                    //   REPORT_SIZE (4)
       0x05, 0x09,                    //   USAGE_PAGE (Button)
       0x19, 0x01,                    //   USAGE_MINIMUM (Button 1)
       0x29, 0x04,                    //   USAGE_MAXIMUM (Button 4)
       0x25, 0x01,                    //   LOGICAL_MAXIMUM (1)
       0x75, 0x01,                    //   REPORT_SIZE (1)
       0x95, 0x04,                    //   REPORT_COUNT (4)
       0x55, 0x00,                    //   UNIT_EXPONENT (0)
       0x65, 0x00,                    //   UNIT (None)
    0xc0                           // END_COLLECTION
   #DEFINE USB_HID_DESC_LEN          sizeof(USB_HID_DESC)
young
hope this helps
PostPosted: Wed Feb 16, 2005 8:15 am     Reply with quote
http://ww1.microchip.com/downloads/en/AppNotes/91054c.pdf.
From this application report, I first that your device number for a gamepad is wrong. it should be 5 instead of 4. see the detailed application about the description. see if it help
