Restricted memory
alexz
Restricted memory
PostPosted: Wed Feb 16, 2005 9:59 am     Reply with quote
When some variables in the watch window are "Restricted memory",
what does it mean?
Alex
PostPosted: Wed Feb 16, 2005 11:38 am     Reply with quote
Read this thread on the Microchip forum, regarding ICD2 memory usage:
http://forum.microchip.com/tm.asp?m=49032&mpage=1
alexz
PostPosted: Thu Feb 17, 2005 3:33 am     Reply with quote
It was said there:
Make sure that you set the "Link for ICD 2" option in the linker build options.
I went to Project->Build Options->Project->General and in the Linker-Script Path field I indicated the directory ICD2.
I am not sure is it is correct what I have done but it didn't help.
Alex
Mark
PostPosted: Thu Feb 17, 2005 7:02 am     Reply with quote
CCS doesn't use a linker. That thread was referring to another compiler. The pointer of reading the thread is supposed to show you that the ICD debug executive program needs some resources. Some RAM and Code space. The restricted is memory used by that.
alexz
PostPosted: Thu Feb 17, 2005 7:05 am     Reply with quote
Does it mean that variable is not active or does not exist?
How can I create a variable and make sure the ICD2 does not use it, that I will be able to watch it?
Alex
Mark
PostPosted: Thu Feb 17, 2005 7:07 am     Reply with quote
Just declare the variable and then add it to the watch window. It is that simple. Are you trying to locate it in a certain memory location?
alexz
PostPosted: Thu Feb 17, 2005 7:10 am     Reply with quote
That's what I am doing
Not at all
Alex
Mark
PostPosted: Thu Feb 17, 2005 7:13 am     Reply with quote
That's about all I can tell you. It works for me. You next option would be to post a small test program that demonstrates the problem. Include the compiler version and IDE version.
