Equivalent programming language
jess
PostPosted: Tue Feb 15, 2005 11:11 am     Reply with quote
hi there, i have a source code written for ccs compilers but i don't quite understand some terms used as i'm more familiar with C. can anyone tell me where i can compare/refer to the equivalent meaning of terms in the ccs compiler source code with C language? thanks a lot!
dyeatman
PostPosted: Tue Feb 15, 2005 12:22 pm     Reply with quote
I am not aware of any "translation" document out there. Because this is an embedded processor compiler and not for x86 there are a number of PIC specific lines that have no equivalent to regular C.
Examples:
#fuses HS,LVP,WDT,NOPROTECT, PUT, NOBROWNOUT = set up processor specific features
#use delay(clock=10000000) = tell compiler what speed oscillator you are using
#use_RS232 = setup up RS232 commuincations functions
#use_I2C = setup up I2C commuincations functions
setup_adc(ADC_CLOCK_DIV_32); = setup analog to digital coverters
There are comparators, PWM, ports, inputs, outputs, and much, much more, NONE of which are known in the regular C world and therefore there is no translation. You will need to learn much more about PIC processors to understand most of this.
