Slick05
Program not working... error in CCS? |
Posted: Sun Feb 13, 2005 3:25 pm |
Hi, this code is supposed to output a 16 bit number on LEDs. The problem is that when I simulate it, it works as it should. But when I program it onto the chip, it doesn't work. I think it is an error within the CCS compiler. Are there other ways of doing this? Here's the code...
[code]
freq=700;
j = make8(freq,1);
output_c(j);
k = make8(freq,0);
output_d(k); |
Posted: Sun Feb 13, 2005 4:11 pm |
Please post a complete working program, the processor and the CCS version you are using.
Also describe what results you observe, just saying 'it doesn't work' isn't very helpful. Are any output changing? If yes, on both port C and D, or just on one port? Etc. |
valemike Guest
Posted: Sun Feb 13, 2005 5:33 pm |
Ckielstra's right. Just because the snippet of code you posted and simulated may work, we don't see the other parts of your source code, especially the #fuse settings you chose. If you chose the wrong #fuse settings, then your chip won't work at all. |
