Calamar
Joined: 07 Sep 2003 Posts: 60 Location: Buenos Aires (Argentina)
where is the problem ? |
Posted: Tue Sep 13, 2005 10:03 am |
using the following code without initialize index
will hung-up the MC(16f877a) only some times, when
local_funtion() is called at firsttime after power-on, any idea ?
// gloabal declaration
const int cursorX[] = {16,13,11,10,8,7,6,5,4,3,16,9};
int index;
loacal_funtion(){
int xPostion;
xPosition = cursorX[index];
} _________________ Best Regards
Daniel H. Sagarra
La Plata (Argentina) |
rwyoung
Posted: Tue Sep 13, 2005 10:12 am |
Then initialize RAM at reset so your index variable will be zero.
Or declare it as _________________ Rob Young
Mark
Re: where is the problem ? |
Posted: Tue Sep 13, 2005 11:51 am |
Calamar wrote: | using the following code without initialize index
int index;
loacal_funtion(){
int xPostion;
const arrays are hangled with return with literals in the w reg. So if index is a random value, what are the chances that the program instruction that it will jump to (call actually) is a retlw? Slim to none and thus explains the problem. Better programming practice would be to do a bounds check to make sure that the index is within the range of cursorX. |
Calamar
Posted: Tue Sep 13, 2005 3:06 pm |
You both are righ I must should initialize index, verify bounds
and so on, but why the MC get lost ?perhaps mark did it
but I didnt get it _________________ Best Regards
Daniel H. Sagarra
Calamar
Daniel H. Sagarra
Posted: Tue Sep 13, 2005 3:42 pm |
The 'key', is in how constant arrays are stored on the 16 family chips. On these, there are no instructions to access the program memory. So how do you store the numbers?. The answer, is the instruction 'RETLW', which returns to the program that called it, with the byte held in the rest of the word holding the instruction. So to access a constant array, what is done, is a subroutine is called, which then adds the index to the current program counter address, and jumps 'into' the array, where there is a RETLW instruction to return the required byte.
If your index is outside the range of the array, you will be jumping to another location in memory, with a return address on the stack, and never return.
CCS, do no bounds checking, because it costs time. Hence you have to either ensure that the value will always be legitimate, or implement your own bounds check.
Calamar
Posted: Wed Sep 14, 2005 10:02 pm |
It`s, clear now, thank you and mark _________________ Best Regards
Daniel H. Sagarra
