PROBLEM ON GRAPHIC LCD
PostPosted: Wed Feb 16, 2005 8:46 am     Reply with quote
I WORKING ON 128*64 GRAPHICAL LCD & EVERY THING IS OK BUT WHEN I SELCET THE OTHER PART OF LCD(CS2) THE LAST BYTE OF DATA IS WRITTEN AT BEGINING OF THE LCD.
IS ANY ONE HERE THAT WORK OR FACING THIS PROBLM?
PostPosted: Wed Feb 16, 2005 8:56 am     Reply with quote
Just for starters: try adding 0x20 to the characters you put on the screen Rolling Eyes Laughing
treitmey
PostPosted: Wed Feb 16, 2005 10:08 am     Reply with quote
You don't say what controler you are using. I have done work with the T6963 controler 128x64. That controler requires you to set the number of bytes across the screen. If its off by 1 then it sounds like a problem where someone started counting with zero and someone else started counting at 1.
