Why am I getting an error?
Slick05
PostPosted: Sat Feb 05, 2005 3:58 pm     Reply with quote
Hi, I have a program to determine the frequency of an incoming analog signal. The main program builds and runs fine, but when I insert the simple subroutine "get_freq", I get all these errors popping up. Why is this happening?
//Frequency determination
#include <18F458.h>
#device ADC=8   //set for 8 bit A/D
#use delay(clock=40000000)   //40Mhz
#fuses HS, OSCSEN, BROWNOUT, BORV20, STVREN, DEBUG //High Speed, Oscillator switching enabled, Brownout reset at 2.0V, Stack full causes rest, Low Voltage programming
int i = 0;
int sig[1300];   //array for signal data
int test=0;      //To test if input is above voltage threshold
int freq=0;      //Global variable for the frequency of the incoming signal
int peaks=0;   //Global vairables for number of peaks counted
void get_freq(void)
   freq=0;   //reset previous values
   peaks=0;
   for(i=2;i<1298;i++)      //take 1300 samples (.325 seconds worth))
      if(sig[i]>=sig[i-1] && sig[i]>=sig[i-2] && sig[i]>=sig[i+1] && sig[i]>=sig[i+2])
         peaks=peaks+1;   //Tests to see if current sample is greater that the 2 before and after
enable_interrupts(INT_AD);
enable_interrupts(global);
setup_adc_ports(RA0_ANALOG);   //Set A0 for analog input
setup_adc(ADC_CLOCK_DIV_32);   //clock frequency
set_adc_channel(0);   //Use PORT A0 to read incoming signal
while (1)
   test = 0;   //initialize test
   test = read_adc();
   if(test>=150)    //Wait until input signal is above certain threshold (So noise isn't "tuned")
      output_d(0b00000000);   //"Tuning"
      for(i=0;i<1300;i++)      //take 1300 samples (.325 seconds worth))
         sig[i] = read_adc();
         output_c(sig[i]);      //Dsiplay sampled value
         delay_us(250);      //4kHz sampling frequency
      get_freq();   //obtain frequency of digital signal
      //setup_adc( ADC_OFF );         More A/D options
      //read_adc(ADC_START_ONLY);
      //value=read_adc(ADC_READ_ONLY);
         output_d(0b00000001);   //Output "ready" light
Slick05
PostPosted: Sat Feb 05, 2005 4:04 pm     Reply with quote
When I take out the for loop in the get_freq routine it compiles fine. What is wrong?
Slick05
PostPosted: Sat Feb 05, 2005 4:17 pm     Reply with quote
I have done alot of testing and actually think it is a bug within CCS. How could I get around this?
PostPosted: Sat Feb 05, 2005 4:20 pm     Reply with quote
Remember an integer in the CCS C, is only 8bits. 255max. You are trying to count up to 1298....
Slick05
PostPosted: Sat Feb 05, 2005 4:21 pm     Reply with quote
Actually don't worry about it, I'm an idiot. One of the braces was the wrong way ;P. I just spent hours trying to figure that one out. What a good waste of time
Humberto
int i = 0;
In CCS C Cross Compiler, integer size is 8 bit by default.
When define a variable and to ovoid mistakes, I use int8, int16, etc
void get_freq(void)
int16 i;
   peaks=0;
Hope this help.
Humberto
