MPLAB Simulator usage with CCS
darrepac
PostPosted: Tue Feb 01, 2005 2:51 pm     Reply with quote
Thanks to the forum I have succesfully integrated CCS uinto MPLA... Now I can compile. Now I want to use the MPLAB Simulator to test my program... I only see the C code of my program and each time I put a breakpoint and run I have an error sayon that my breakpoint could not been resolved...
1) How to handle Simulator with CCS?
2) Is it possible to have access during run, and step-by-step to the LST file in order to have a better view of where are exactly the PC
Pascal
darrepac
PostPosted: Wed Feb 02, 2005 3:23 pm     Reply with quote
Nobody is using MPLAB Simulator with CCS?
If you have other simulator (free if possible) to recommend...I am open.
Mark
PostPosted: Wed Feb 02, 2005 3:43 pm     Reply with quote
Sure. It just works.
darrepac
PostPosted: Wed Feb 02, 2005 4:06 pm     Reply with quote
Fine!
How are you using it? you are simulating with only the C code? not the corresponding assembler code?
Is there a trick to be able to put a breakpoint?
Thanks!
PostPosted: Wed Feb 02, 2005 6:23 pm     Reply with quote
For a question like this, you should give the version of MPLAB
that you're using (and the compiler version, too).
Mark
PostPosted: Wed Feb 02, 2005 9:07 pm     Reply with quote
Post a small test program too. Keep it simple and specify what line you tried putting a break point.
darrepac
PostPosted: Thu Feb 03, 2005 8:14 am     Reply with quote
I am using CCS 3.181 and MPLAB 7.0... for a small program test I will try to do it...
darrepac
PostPosted: Thu Feb 03, 2005 8:25 am     Reply with quote
Ok by doing the small test program and seeing that it works I have found from where the mistake come.. In fact it doesn't work if I put for example a breakpoint on the if statement but it works well on other instruction (for exemple the instruction before or after the if)....is it normal?
darrepac
PostPosted: Thu Feb 03, 2005 9:18 am     Reply with quote
OK, I finally found the disassembly listing view which is far easier for me...
