Detecting a 0 to 1 transistion(rising edge) on a pic i/p
SlimG
PostPosted: Fri Feb 04, 2005 4:46 am     Reply with quote
Im trying to detect a 0 to 1 transistion on a pic i/p pin using a while loop.
Here is the code I have writen.
int sample_1, sample_2;
sample_1 = input(pin_a0);
sample_2 = input(pin_a0);
while (sample_1==1 && sample_2==0) // the condtn does work, it fails both ways
bla;
bla;
What i want is for the loop to continue when sample_1 is 0 and sample_2 is 1, but for the loop to fail when sample_1 is 1 and sample_2 is 0
can anyone help?
thanx people.
Regards
valemike
PostPosted: Fri Feb 04, 2005 6:58 am     Reply with quote
What you are doing is sampling sample_1 and sample_2 back-to-back. 99.999% of the time you will always get the same value on both. You should be sampling inside the while-loop. In fact you don't need two variables, just one.
// if the pin is '1', wait for it to be '0'; if the pin is already '0' you'll zoom right past this first while-loop
while (input(PIN_A0));
// ok, the pin is now '0'; wait for the 0 to 1 transition...
while (!input(PIN_A0));
Of course, if you have your watchdog timer enabled, then you'll have to refresh the watchdog timer inside the while loops
restart_wdt();
Mark
PostPosted: Fri Feb 04, 2005 7:10 am     Reply with quote
If you want a second opinion, mine is the same as valemike's Very Happy
Re: Detecting a 0 to 1 transistion(rising edge) on a pic i/p
PostPosted: Fri Feb 04, 2005 8:46 am     Reply with quote
bla;
bla;
can anyone help?
thanx people.
Regards
There are other ways. You did not say which PIC you are using.
If the PIC has interrupt ability, then why not let the hardware do the work.
Using an Interrupt pin set to deetct the rising edge it is possible to detect a trasistion from 0 to 1 and never miss a transition.
