struct in struct
hayri
struct in struct
PostPosted: Sun Jan 30, 2005 3:37 pm     Reply with quote
struct
   byte A_last;
   byte B_last;
   byte C_last;
   byte D_last;
   struct A {int1 changed; int1 pressed;};
   struct B {int1 changed; int1 pressed;};
   struct C {int1 changed; int1 pressed;};
   struct D {int1 changed; int1 pressed;};
} Buttons;
void InitButtons()
   buttons.A_last = 255;
   buttons.B_last = 255;
   buttons.C_last = 255;
   buttons.D_last = 255;
   buttons.A.changed = false;
   buttons.A.pressed = false;
   buttons.B.changed = false;
   buttons.B.pressed = false;
   buttons.C.changed = false;
   buttons.C.pressed = false;
   buttons.D.changed = false;
   buttons.D.pressed = false;
here is InitButtons() asm code....
.................... void InitButtons()
.................... buttons.A_last = 255;
0D7C: MOVLW FF
0D7E: MOVWF 74
.................... buttons.B_last = 255;
0D80: MOVWF 75
.................... buttons.C_last = 255;
0D82: MOVWF 76
.................... buttons.D_last = 255;
0D84: MOVWF 77
.................... buttons.A.changed = false;
0D86: BCF 73.0
.................... buttons.A.pressed = false;
0D88: BCF 73.1
.................... buttons.B.changed = false;
0D8A: BCF 73.0
.................... buttons.B.pressed = false;
0D8C: BCF 73.1
.................... buttons.C.changed = false;
0D8E: BCF 73.0
.................... buttons.C.pressed = false;
0D90: BCF 73.1
.................... buttons.D.changed = false;
0D92: BCF 73.0
.................... buttons.D.pressed = false;
0D94: BCF 73.1
0D96: GOTO 1704 (RETURN)
as you can see in asm code
0D86: BCF 73.0
0D8A: BCF 73.0
buttons.A.changed and buttons.B.changed (and others) converted to exactly same asm code (BCF 73.0). both of code uses same memory and everything goes wrong.
i want to differend bytes, bits. (example)
buttons.A.changed = false; --> BCF 73.0
buttons.B.changed = false; --> BCF 73.2
what is i'm doing wrong?
can i use structs in another struct to get this?
thanks.
PostPosted: Sun Jan 30, 2005 6:15 pm     Reply with quote
change
struct
   byte A_last;
   byte B_last;
   byte C_last;
   byte D_last;
} Buttons;
to
struct
   byte A_last;
   byte B_last;
   byte C_last;
   byte D_last;
   struct {int1 changed; int1 pressed; A};
   struct {int1 changed; int1 pressed; B};
   struct {int1 changed; int1 pressed; C};
   struct {int1 changed; int1 pressed; D};
} Buttons;
hayri
PostPosted: Mon Jan 31, 2005 2:14 pm     Reply with quote
thanks a lot Ckielstra Smile
it is absolutely my fool...
this one also worked well. (but used different bytes for each struct - bits 70.0, 71.0 ... only for information)
typedef struct
   int1 changed;
   int1 pressed;
}btn;
struct
   byte A_last;
   byte B_last;
   byte C_last;
   byte D_last;
   btn A;
   btn B;
   btn C;
   btn D;
} Buttons;
