Don P
21 bit max ? ! |
Posted: Tue Jan 25, 2005 6:39 pm |
I define a variable as int32.
Using "0b" binary notation to equate it to a constant, it won't compile if I specify more than 21 bits. Is this known?
Regards,
Don |
rwyoung
Posted: Tue Jan 25, 2005 7:28 pm |
Can you post with your compiler version number and short (but complete) program demonstrating the issue? _________________ Rob Young
Don P
Posted: Tue Jan 25, 2005 7:41 pm |
#include <16F628.h>
int32 X ;
void Main()
X = 0b11110000111100001 ; // add another digit and you get
// *** Error 76 "junk.c" Line 5(24,25): Expect ;
I used to know where to find the compiler ersion, but it's not apparent since it's combined with MPLAN 6.60
Tell me where.
Regards,
Don |
Posted: Tue Jan 25, 2005 9:06 pm |
Quote: | I used to know where to find the compiler version |
There are at least three ways to find the compiler version.
1. Compile a test file, and look at the top of the .LST file.
It will show the version.
2. Click on Start/ Programs, and then find the entry for CCS.
It might be called "PIC-C". Then click on the icon for "Compiler Version".
2. Open a DOS window and go to c:\Program Files\Picc
and run this command line: CCSC +v |
Don P
Posted: Tue Jan 25, 2005 9:35 pm |
Ah ha !
ver 3.152 |
works OK in 3.216 and 3.190 |
Posted: Tue Jan 25, 2005 10:04 pm |
Version 3.216 and both 3.190 work OK, no problem |
Don P
Posted: Tue Jan 25, 2005 10:32 pm |
OK, unless it's a free upgrade, I can live with it. |
